Battery Indicator going down when parked
Old Apr 21, 2008 | 05:26 PM
lexasgs400's Avatar
Default Battery Indicator going down when parked
I bought my 2006 HCH with 64000 miles on it about a month ago and love the economy so far averaging 48 mpg through the first 1500 miles. Twice in the last week I went into a store once for about 10 mins and the other for about an hour when I came out my battery indicator read one bar. Does anyone have any ideas? A drain? Bad battery? Normal?
Old Apr 21, 2008 | 07:05 PM
msantos's Avatar
Eco Accelerometrist
Default Re: Battery Indicator going down when parked
Jason, welcome to GreenHybrid !!!
Don't worry about that phenomenon... unless it happens frequently. The system will,once in a while cause that "depletion" and then attempt a charge to re-set the upper SoC limit.
As I said, if this begins to happen frequently (as in more than once a day or so) and you can clearly see that the SoC has trouble staying at or above 5 bars, then I would take it in to the dealer for a quick check-up.
Cheers;
MSantos
Old Apr 21, 2008 | 11:30 PM
rysa4's Avatar
What does SoC stand for?
Old Apr 22, 2008 | 04:53 AM
msantos's Avatar
Eco Accelerometrist
SoC stands for State of Charge and is represented by the battery charge level display on the HCH-II.
MSantos
eoq87
Aug 7, 2017 08:53 PM
Smurf
Oct 11, 2011 07:58 AM
bwilson4web
Jul 21, 2006 12:40 PM
