Balancing hybrid battery
After having my IMA battery out of the car but 20 times going through the sticks although it helps is to the point to where it's not assisting but it still has have voltage in the 180s constantly. But does not asist at all anymore. My question is after the voltage tops on the charging side and then it starts going down how do you know when the balance voltage is reached? I feel this is the only chance to start getting an assist from this battery pack? Does anyone have any idea of why it does not exist anymore even with the high-voltage thanks I look forward to any replies only
As a former owner of 2 HCH2 and the not-so-proud owner of about 9 packs worth of subpacks (yes, 99 subpacks), with nearly all of them being bad, I feel your pain. This doesn't include the 2 good ones that went with the car.
"going through the sticks" - given the fact that I have horrible experience with these, I suspect that your efforts at "going through the sticks" failed.
You need to check the tap voltages via the orange connector from the battery to the BCM. you don't need to unplug it. You just probe from the wire end:
https://www.greenhybrid.com/forums/f...tml#post261753
Measure those to .XX accuracy and report back.
Steve
P.S. what codes are present?
Steve
jeffemcguire
Aug 10, 2016 08:26 PM
alsadi
Oct 23, 2012 06:00 AM
Rickhandling
Jun 22, 2012 10:36 AM
cmcd
Oct 27, 2008 03:59 PM
hsolo142
Toyota Highlander Hybrid
16
May 25, 2006 10:59 PM
