Autostop Tip
Old Jul 21, 2006 | 11:32 AM
moosh's Avatar
Owner
Default Autostop Tip
If for some reason the autostop doesn't engage while at a complete stop. Try pressing the brake pedal ALL THE WAY DOWN after it's apparent that the auto stop won't kick in. Sometimes the auto stop will engage, where it didn't if the brake pedal just had normal pressure on it during a stop.
Old Jul 21, 2006 | 06:04 PM
willdorr's Avatar
Default Re: Autostop Tip
Moosh is right!
This has been my experience also. When I'm stuck in traffic, and I'm able to inch forward from autostop, the car will go back to autostop if I depress the brake ALL THE WAY and hold it.
Old Jul 21, 2006 | 11:44 PM
philmcneal's Avatar
04 prius 350,000km
question, since the hch allows you to creep like a normal automatic with a torque converter, does your mpg meter drop when you just let go of the brake? or does IMA ASSIST helps you creep forward before actually injecting gas into the engine?
Old Jul 22, 2006 | 04:31 AM
HyChi's Avatar
Good question, Phil. I really had to think on this one. (or maybe it's just because I haven't had my morning coffee yet.) When you let your foot off the brake the ICE starts up and the iFCD is at zero. When you depress the gas pedal the IMA assist kicks in to help the ICE get the car up to speed. The Tarabell and PCK have been trying to get their cars to use the IMA alone with some success, but I have not as of yet. So, whenever I let up on the brake and begin to move forward the displayed mpg drops. Depending on the situation and how quickly I need to get up to speed the iFCD is usually around 15-25mpg during initial acceleration.
haroldo
Mar 24, 2008 07:41 AM
tbaleno
Dec 22, 2005 09:03 PM
hawkGT647
Honda Insight
Nov 21, 2005 10:41 AM
krousdb
Oct 22, 2005 11:49 AM
kenny
Aug 19, 2004 02:57 PM
