Auto Stop Discussion
Old Aug 28, 2008 | 01:31 PM
Hybrid Bob J's Avatar
Default Auto Stop Discussion
So, I've had my car for about 2 weeks. Still on the same tank of gas.
My Auto Stop comes on almost every time I come to a stop sign or traffic light.
First question: With the car gas engine stopping then starting like it does with Auto Stop, will this eventually damage the starter?
Second question: Is there a way to shut this feature completely off? If it is working normally and won't hurt the starter...then disregard question 2.
BTW: With 1 bar above half a tank left...I'm at about 39.5 mpg and still climbing.
HBJ
Old Aug 28, 2008 | 01:57 PM
mmrmnhrm's Avatar
Wo ai Zheng!
Default Re: Auto Stop Discussion
1. No. Your crankshaft is started using the same electric motor that provides the torque boost while accelerating, and the battery regen while slowing down. While the HCH2 does have a traditional starter, you'll almost never use it (In the 2.5 years I've had mine, I've had it turn over *once*, and it's a very different sound than the IMA motor start).
2. Sure. Cut the IMA wires :p Seriously, though, what you're seeing is the way it's designed. No need to worry.
Old Aug 28, 2008 | 10:55 PM
bill717's Avatar
When approaching stop signs, as I slow down I engage the windshield defogger. This prevents the car from autostopping. You can turn the defogger off when you come to a complete stop. Autostop is not necessary unless you know you will be stopped for ~10 seconds. I try to limit autostop when its not necessary in order to conserve charge.
Old Aug 29, 2008 | 05:42 AM
hunter44102's Avatar
Is there a way to avoid this particular re-start from Auto-Stop:
Pulling into the garage, I press the brake when I am fully inside, and the Auto-stop engages. (I am still in Drive gear)
As soon as I move the shifter to PART, the car re-starts.
It would be nice if it stayed off since I am parking. You would think the Auto stop logic would be smart enough to stay OFF if you move the lever to park, especially when my foot is still on the brake.
(I have a 2006 HCHII)
Old Aug 29, 2008 | 06:07 AM
kristian's Avatar
Or, even easier, you can slide the tranny into S. That's what I do for 4 way stops and stuff like that where I want to stop, but won't be stopped longer than 6 seconds (the magic number I've seen elsewhere).
Old Aug 29, 2008 | 06:53 AM
Soybean's Avatar
The Auto Stop is the coolest part of the car. I would never want to turn it off, although I can see why in certain situations you'd want to avoid it. Thankfully the posters above have solutions for that. I personally don't worry about it, though.
Old Aug 29, 2008 | 09:25 AM
mmrmnhrm's Avatar
Wo ai Zheng!
This has been discussed often. See https://www.greenhybrid.com/discuss/...-newbie-19349/
Old Aug 29, 2008 | 10:15 AM
Thanks mmrmnhrm - you just help me save some more fuel
Myrddin157
May 24, 2007 06:08 PM
JeremyG
Sep 16, 2005 07:51 PM
grayhawk
Sep 11, 2005 05:55 PM
MoJoWryter
Jun 23, 2005 12:52 PM
Jason
Jan 14, 2004 12:32 PM
