30K Oil Test results - Most Excellent!
Old May 29, 2008 | 02:39 PM
Default filter change interval
I started changing the filter at every second oil change on my Audi a few years ago after I noticed that they were 15 K mile filters. Those filters are a little expensive, so I started doing there mainly because I'm a tightwad.
But on the Civic, for the 1st 3 oil changes, I had also changed the filter. But I have seen the light, and this latest filter will not go into the recycle bag until 50K miles.
However, I do recommend changing the filter at the drain of the (first) factory fill, given all of the manufacturing debris that are floating around in that oil.
BTW: I do not have the TBN because that test costs $10 more. If you want to contribute, we can have it done next time around!
Old May 29, 2008 | 02:42 PM
honduhlife's Avatar
Default Re: 30K Oil Test results - Most Excellent!
It wouldn't surprise me if the dealer weren't changing filter on each change. I'm new to the hybrid car, but with the cvt I would think it more similar to a marine engine. You can actually void warranties by changing oil and filter too often, and many have adopted an every other change on the filter.
Old May 29, 2008 | 07:53 PM
holicow's Avatar
Change the filter, it's just good practice. It's too easy not to.
I changed my oil for the first time at 2.6Kmi last weekend. Believe me, it was hard to wait even that long. I will be changing mine most likely eveyr 5k or less after that just for principle. (I'm old) I recycle it, so that part does not bother me.
Oh, I am using 5w-20, also. Go ahead, I'm ready....
Old May 29, 2008 | 07:58 PM
pagemap's Avatar
I'll stick to using Mobil1 0w20 and 10K oil change. Let's check back in at 300K miles and see who's engine is cleaner.
Old May 29, 2008 | 08:02 PM
holicow, what a waste!!! H
Old May 30, 2008 | 04:22 AM
peking's Avatar
"Each to his own" or "To each his own"
P.S. Do what makes you feel the best.
Old May 30, 2008 | 08:49 AM
Soybean's Avatar
Wow, that is an epic waste of oil. Rerefining oil still takes a lot of energy, and even though a lot of recycled motor oil is burned as fuel for electricity or heating, it's still best to use that oil in your engine for as long as you can.
I know not everyone buys a hybrid for environmental reasons, but you'd think a hybrid buyer would have some concern for those issues.
Old May 30, 2008 | 02:09 PM
Default Here is the perfect solution for extending the life of the HCHII oil
Click here for Engine Oil Bypass Kit
Old Jun 3, 2008 | 07:38 PM
HemiSync's Avatar
And who has the better lifetime mpg!
Old Jun 3, 2008 | 09:58 PM
HemiSync's Avatar
Below are the results of the test. I have been using Mobil1 0W-20 in the car since the 10K maintenance, and the Civic engine seems to like it.
Just curious as to which oil filter you are using?
I was looking at the Fram Model PH7317 but realized that it has some kind of additive in the filter and I don't think I want their additive going into my Mobil 1 0W-20 AFE Oil.
Orient Express
Dec 6, 2008 11:23 AM
bwilson4web
Aug 4, 2007 08:34 PM
Orcrone
Oct 18, 2006 06:43 PM
caymandiver75
16
Oct 10, 2005 10:03 AM
AndyT
Sep 21, 2005 03:26 PM
