2008 honda civic hybrid
Old Jan 15, 2023 | 03:10 PM
Mikdew1's Avatar
Default Re: 2008 honda civic hybrid
Ok thank you. Well I did unplug it and took readings from the front side, so I messed up. Just so I don't misunderstand, I need to record voltage with it still plugged into bcm? Does the ignition switch need to be on also?
Old Jan 15, 2023 | 03:47 PM
No. You may do so, but you don't have to. The diagram is for the back of the plug, i.e., as you see it when looking at it when it's plugged in. You can unplug it and probe the pin side as you did, but you have to use the mapping per the back of the plug.
No. Those voltages come directly from the subpacks and are present even when removed from the car.
Old Jan 15, 2023 | 04:45 PM
Mikdew1's Avatar
Thanks for the clarification. I will check these when I get off work in the morning.
Old Jan 21, 2023 | 02:22 PM
Mikdew1's Avatar
Where is B13 and B14
Old Jan 21, 2023 | 02:37 PM
Old Jan 22, 2023 | 02:28 PM
Mikdew1's Avatar
I don't see those in the picture.
Old Jan 22, 2023 | 02:43 PM
I don't know how to explain it to you. They're right there on the image.
Can you really not see the B13 and B14 pins?
Kevinmce
Introductions
Oct 8, 2025 09:45 AM
GreenBoy
Sep 4, 2010 03:16 AM
spinner
Jan 16, 2008 06:09 AM
GNiel9
Aug 25, 2007 12:00 AM
MBNorCal
Mar 14, 2007 07:47 AM
