2007 HCH 12 Volt Battery replacement urgent help needed!
Old Oct 12, 2011 | 05:46 PM
hansonclan's Avatar
Default Re: 2007 HCH 12 Volt Battery replacement urgent help needed!
Thanks! My 12v just died. I'll do what you did. Where'd you get the $30 coupon?
Old Oct 12, 2011 | 06:01 PM
AJR's Avatar
AJR
First you need to have an Advance Auto Parts store to pickup the battery - they won't ship batteries.
Second, You can use coupon code D123 at checkout to get $30 off $100 (or $20 off $50, or $10 off $30).
Also hans, check your PM... I sent you a message.
Old Feb 25, 2017 | 12:24 PM
mpk's Avatar
mpk
Originally Posted by AJR
The 51R is about 2-4" wider than the 151R so the OEM plastic batter cover that went over the battery can't be used with the 51R, but the mounting bracket holds the battery in place well. If you get one, be sure to get the AutoCraft 51R-2 which is 500 CCA that matches the OEM, whereas the 51R-1 is only 430 CCA.
Sorry to dredge up an old thread, but did you order a battery cover and plastic base for a regular civic? Or did you just remove the too-small cover and base and just use the mounting bracket?
I assume the cover reduces engine heat to the battery.
Old Feb 25, 2017 | 02:30 PM
Dream'R's Avatar
The size 51R battery will work fine without the plastic base and external side cover. I don't think the difference in heat exposure should be an issue since the battery is located away from the hottest parts of the engine.
The 51R is very popular so easy to find and has much greater capacity than the much smaller OEM size 151R.
As my much earlier posts mentioned, this has been a very common solution for other HCHII owners.
Captain Jim
Mar 27, 2021 03:23 PM
vicki777lee
Dec 8, 2010 10:59 AM
Rcommander
Aug 8, 2009 10:37 PM
spud
Sep 13, 2006 03:53 PM
