View Poll Results: What is causing the problem with my 12v charging
Ima battery fuse block near 12v positive terminal.
0%
Water leaking through back window into the trunk area. Due to shotty replacement job.
0%
Intelligent power unit?
0%
PCM??
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
2006 HCH 12V Accessory battery won't charge. Gauges flashing and car dies @20mins dri
Hello new to The Forum of course I'm here because I have a problem. I have a 2006 Honda Civic Hybrid while doing my road test at DPS the car has died I replaced the 12 volt battery. Same issue. Car will drive but won't charge the 12v battery. The IMA IS CHARGING. The problem is the 12v isn't charging... could be a fuse. It was too cold to stay and work on it last night. Ima has been replaced like 2 years ago. Engine only has about 70k ish. Body has 240k. This thing is killing my wallet.. any of you gurus familiar? Seems like its something easy. It's been kinda jerky when you get/onlet off the throttle at times.. anybody know?? I replaced all the mounts when I swapped the engine at around 210k body mileage. I Would give anything to have my family's car back on the road. Pls let me know if you got any advice folks. Thank you and GOD BLESS🙌🙌
Michaela Scanlon
Jan 16, 2019 11:01 AM
lmiller8456
Jun 26, 2014 10:11 AM
smallgulp
Apr 20, 2007 04:09 PM
