2006 Civic Hybrid Won't Turnover
Old Dec 3, 2017 | 05:20 PM
Bigfoot100's Avatar
Default Re: 2006 Civic Hybrid Won't Turnover
Took the original Honda starter to Advance Auto and had it tested. The starter is fine. Now I'm really frustrated with the dealer, since they told me they double-checked and were sure that the starter was bad.
Anyway, any advice on next steps for troubleshooting would be greatly appreciated.
Old Dec 3, 2017 | 05:58 PM
Basically, you're limited to the:
Battery
ignition switch
#23 relay fuse under dash
starter relay
#1 and #2 under hood series fuses
PCM
starter
transmission range switch
Attached is a diagram of the starter circuit.
Attached Thumbnails 2006 Civic Hybrid Won't Turnover-honda-start-circuit.png
Old Dec 4, 2017 | 08:47 AM
Bigfoot100's Avatar
Thank you very much! Very helpful.
FWIW, my cheapie consumer-grade OBD-II scanner is showing a POAE1 code...
Old Dec 4, 2017 | 08:54 AM
That's the HV battery contactor circuit. It usually means either the main fuse is blown, or the contactor has gone bad. Both require accessing and removing the battery to test components on the junction board.
I don't have access to my manuals at the moment, so I don't know if that code disables the car. I don't think it does, so it should still start from the backup starter.
Did the dealer give you codes?
You also need to make sure that the 12V remains charged. I would put it on a charger to keep it fully charged.
Old Dec 8, 2017 | 12:24 PM
Bigfoot100's Avatar
Btw, which one is the starter relay? The diagram on the under-hood fuse box does not have text describing the relays, so I don't know which one it is. Thanks.
Old Dec 8, 2017 | 02:28 PM
Diagram I included says under-dash.
See below.
Old Dec 9, 2017 | 10:30 AM
Bigfoot100's Avatar
Thank you!!! I have now confirmed that the ignition switch and starter relay are good. I jumpered across the load terminals of the starter relay socket (relay removed), and the car started! From the diagram Keith provided, this seems to indicate that the problem is with the PCM or the transmission range switch. Does anyone know where the transmission range switch is on this car?
Old Dec 9, 2017 | 12:02 PM
Bigfoot100's Avatar
Never mind on the Transmission Range Switch. I found it (thanks to a $10 1-day subscription to the tech Honda service site), checked it, and the test passed. So... I suppose this means I probably have a PCM issue. Scary. Is there a PCM reset that I can perform without having Honda's diagnostic system? I only have a cheapie handheld OBD II scanner.
Old Dec 9, 2017 | 04:05 PM
Given that this all started after a very long sit - here's what I'm thinking - you have two issues:
1) your IMA battery discharged to the point that the car won't start with IMA.
2) The backup starter system isn't working.
Given that you have found a way to get the backup starter to start the car, it may be worthwhile to see if it will charge the IMA battery. Let it idle for 10-15 minutes. Disconnect 12V for 1 minutes, reconnect and try again. Continue this until the car has charged the battery to full 3 times.
If you can get the IMA battery back to a healthy state, this becomes an annoyance.
Generally, PCM errors have codes and cause strange things to happen.
12V disconnect usually causes all ECUs to reset; however, there is a specific PCM reset within HDS, so it's possible that's what it needs as the PCM can store data even without 12V power.
Per the diagnostics, did you check for battery voltage at the PCM connecter pins A12 and A7 to ground with the key in the start position?
Old Dec 14, 2017 | 06:20 AM
Bigfoot100's Avatar
