2006 Civic Hybrid IMA+CEL light permanently on
Old Mar 22, 2024 | 02:54 PM
Default Re: 2006 Civic Hybrid IMA+CEL light permanently on
That's excessive. If you've done that recently, there is nothing to be gained from subsequent discharges.
Old Apr 27, 2024 | 09:26 AM
WessyD's Avatar
Quick update,
I took the pack back to greentec & upgraded to their mid range offer of a higher quality higher capacity pack, and the MPG was immediately deff better (between 38-40).
I'm in the middle of cycle grid charging to recondition it and noticed that the cooling fan isnt coming on when grid charging. i checked the volts that the grid charger is outputting to the fan and its 2.6v
Do you think the fan motor is burned out from using it too much, OR grid charger is messed up OR is the new battery giving it so little feedback that it doesn't think the cooling fan needs to be on?
Old Apr 27, 2024 | 09:34 AM
Grid charger directly powers the battery fan. There is no communication between the vehicle/charger/fan when grid charging.
I've never seen a fan fail.
If output is 2.6V to the fan, I would conclude the grid charger has failed.
Do not charge without active cooling. Period.
Old Apr 27, 2024 | 10:01 AM
WessyD's Avatar
****! i dont want to stop the charge cycle.
do you think pointing a house fan directly at the battery would be enough?
Old Apr 27, 2024 | 10:26 AM
grid charging without active cooling will destroy a battery.
Old Apr 27, 2024 | 11:00 AM
WessyD's Avatar
Alright, i yanked the two wires that go to the fan out the side and put the panel back on, shaved a bit of the plastic sheathing off the wires and hooked a 12v batt charger up to them. Fan is blowing strong now.
Couple shots of the nightmare going on in the backseat right now for ***** & giggles lol
Thanks again for the help S. Keith
Old Apr 27, 2024 | 06:34 PM
  #27
I think you've established what has failed.
Old Apr 27, 2024 | 06:41 PM
  #28
WessyD's Avatar
yeah, irritating too, the MaxxVolts grid charger is brand new...
Old Jun 9, 2024 | 06:54 PM
  #29
WessyD's Avatar
Yo SKeith. I think something might actually be wrong with the fan. I get a P1448 error code now...
and now that i think about it i dont ever hear it click on while driving (and i should, i have the back seat still out)
I checked all fuses and they're fine.
Old Jun 9, 2024 | 07:49 PM
  #30
37 diagnostic steps in the manual checking many pins on the Fan and BCM module.
Resolutions include repairing wires, repairing shorts, BCM flash, BCM replacement, fan replacement.
noproblem07camry
Aug 26, 2020 03:00 PM
LevisJeanz
Apr 12, 2017 12:45 PM
hjb417
Apr 10, 2013 04:01 AM
Adjat84th
Jun 25, 2008 02:33 PM
carbnjunkie
Jan 30, 2008 12:30 PM
