2006 Civic Bad Transmission
Old Apr 17, 2010 | 09:25 PM
lmwerk's Avatar
Default 2006 Civic Bad Transmission
My vehicle has been making a loud clicking.shirring noise so we took it to the dealer today.
Turns out that there is a bad bearing in the transmission and we need a new trans.
I t was covered under the 5/50 powertrain butthis shouldn't have happened in my opinion. Anyone else experience this issue?
Old Apr 18, 2010 | 07:33 AM
Default Re: 2006 Civic Bad Transmission
Did they actually replace the CVT. You would think they would just replace the bearing. Must be very labor intensive if they change the whole thing out? H
Old Apr 18, 2010 | 09:27 AM
Mendel Leisk's Avatar
There is a very extensive section in the Service Manual regarding transmission re-build. It's likely impractical, and too expensive (in labour) for the dealership to do. Dealership mechanics are good at diagonistics (Knock on wood...) and parts add/swap. I wonder if it's similar to other complex part swaps: your transmission goes somewhere, is torn-down and re-built by skilled specialists, and your "new" transmission is actually someone else's, gone through the same process. They should tell you, if this is the case.
Lin, just for the record: is your Civic the Hybrid model, with the Continously Variable Transmission?
Anyway, stuff happens. As long as they are quick and agreeable to fix it, and do it right, it sounds like you have a good dealership.
mishra
Apr 17, 2008 05:37 AM
davidwells
Sep 27, 2007 02:51 PM
gpsman1
Nov 29, 2006 05:45 AM
ekc
May 11, 2006 10:06 AM
pfezziwig
Mar 23, 2006 06:24 PM
