1st oil change came sooner than expected
Old May 1, 2010 | 10:00 AM
stevenvillatoro's Avatar
Arrow 1st oil change came sooner than expected
My '09 has 6,500 miles, and I just got the service reminder that 15 percent of my oil life remains. The car is 14 months old. I drive conservatively, and do about 50 percent freeway driving. What have others found to be a typical mileage interval for the first oil change? Thanks!
Old May 1, 2010 | 11:58 AM
Default Re: 1st oil change came sooner than expected
Hey Steve, your not to go over a year on the same oil!All kidding aside, My 2006 normally goes to about 14000 kilometers per oil change. Yours does seem to be early for sure. Maybe it is do to the age of the oil? Anyway 15% lasts for awhile, so you may get to 8000 miles
H
Old May 1, 2010 | 03:38 PM
Red's Avatar
Red
Most vehicle oil change intervals are either mileage or time - whichever comes first. I suspect you are over on the time limit. If you do a lot of low speed, short distance driving, your oil will accumulate moisture (water and gas blow-by fumes) that will over work the oil additives (high engine temps tend to burn off the moisture). Most oil change reminders are mileage dependent.
Look at your maintenance guide. If it says a year, then get it changed quickly.
Old May 2, 2010 | 03:50 PM
Dream'R's Avatar
Steve,
The owner's manual mentions that the oil in the HCHII should be changed after one year even if the reminder hasn't reached the lower limit. You should get it changed fairly soon. The filter is normally changed with every second oil change.
A regular contributor to these forums has an oil analysis done each time and follows a 10,000 mile interval with very good reports. Mobil 1 in 0W-20 weight is a preferred oil once the motor has been broken-in, which yours is now.
I'm sure no harm has been done. You may even see a bit better mpg with new full-synthetic oil in the motor.
Cheers,
Roger
Old May 2, 2010 | 05:38 PM
Arrow Re: 1st oil change came sooner than expected
Thanks, all. I appreciate your feedback!
Yes, I've been eager for my reminder to come on, so I could change to synthetic. I had planned on Amsoil, but may opt for Mobil 1 or similar for convenience.
I'll be pleased to pick up a MPG or 20.
Old May 2, 2010 | 09:01 PM
Mendel Leisk's Avatar
We've been consistantly hitting 15% around 9000 km, plus/minus 500 km. That's with a fairly high percentage of short, local trips.
Old May 7, 2010 | 05:54 PM
sublme's Avatar
I just switched to amsoil 0w-20 and have noticed a couple MPG increase, nothing huge but something. The one thing I have noticed is seems like my oil life is not dropping as fast. I will update with how many miles I got between oil changes on the honda 0w-20 compared to amsoil, I am curious to see if there is any substantial mileage increase between changes. I switched cause I can use Amsoil and change it myself for cheaper than the dealer with honda oil.
Curated Content Editor
Mar 29, 2013 05:21 PM
gezundheit
Aug 9, 2012 08:33 PM
thebaron
Feb 19, 2008 06:16 PM
