11 months after initial grid charge, battery stays around 3/4
Old Sep 16, 2020 | 12:40 AM
eride1's Avatar
Default Re: 11 months after initial grid charge, battery stays around 3/4
Turned the desk fan off.
Yes sir the IPU lid is secure.
I just realized my voltmeter came with a thermocouple. I paused charging for about 30 mins and put the thermocouple in by the battery switch, probably not ideal but something
Read about 20 C / 68 F with the lid re bolted in and grid charging again.
​​​​​​12v Battery stayed at 100 percent 5 hours in so looks like im good on that front.
Old Sep 16, 2020 | 06:42 PM
eride1's Avatar
I don't know if my previous post was posted? Not showing up on mobile chrome but does on desktop. But my ipu lid was secured.
179.2 v 7:21 pm Tuesday September 15th
184.1V 7:40pm Tuesday September 15th
186.8V 3:34pm Wednesday September 16th
189.7V 4:25pm
188.6V 6:00pm
Sitting at 24 C / 75 F inside the case.
What's up with the weird fluctuation? Normal?
Should i keep the key in the ignition while discharging?
And I can do the 2 minute disconnect + charge x3 after discharge before grid charging to potentially speed it up right?
Spark plugs just arrived. There's probably nothing wrong with replacing the spark plugs while keys in ignition but I don't think im going to risk it.
Old Sep 16, 2020 | 06:52 PM
Small fluctuations like that aren't uncommon. It's a sign that you're hitting full charge on multiple cells.
Ignition on not necessary for discharging.
4 hour grid charge must occur immediately after discharge. Do not attempt to start car. After 4 hours, you can do the 3X 12V reset to speed it up.
Old Sep 17, 2020 | 11:45 AM
eride1's Avatar
I dun fugged up.
Voltage was sitting at 140 something under load. I came back 1.5 hours later and it was 14V.
2 72W 120v light bulbs in series.
Plugging grid charger in had it at 147V and climbing.
How do I remedy this?
Old Sep 17, 2020 | 02:20 PM
Pretend it didn't happen,
Charge an extra 30 minutes before starting.
Conduct 3X 12V resets/charges
Conduct 8-12 hr topping charge.
I would have omitted the final topping charge.
The rapid drop is potentially a good sign that the discharge was unnecessary. Had there been a lot of recoverable capacity at the lower voltages, it would have taken longer at 36W (2 72W in series are 36W).
For future, when you detect a decrease in performance, conduct 3X 12V reset/charges and overnight charge. It's likely all you need. When that stops getting results, do the single discharge exercise.
Old Sep 17, 2020 | 05:20 PM
eride1's Avatar
Great thank you so much for the reassurance! And the knowledge!
Grid charged for 5.5 hours and and doing the 3x 12v reset/charge now. Ill stop and then begin the grid charge before going to bed.
Old Sep 17, 2020 | 05:35 PM
There are times that the battery may never register full after three charges. If that's the case, with the car in Park, rev the engine to > 2500rpm (or whatever rpm the charge bar shows) and hold it there until the SoC gauge reads full and the car won't charge while revving.
sharrq27
Aug 19, 2024 01:27 PM
rmacgowa
Jun 22, 2020 06:57 AM
95hch1
Jan 4, 2017 01:40 PM
S Keith
Dec 23, 2016 07:23 PM
jjh1
Feb 21, 2016 06:36 PM
