whats needed to convert from a Hybrid?
Old Dec 19, 2009 | 07:40 PM
bigbearballs's Avatar
Default Re: whats needed to convert from a Hybrid?
Originally Posted by jayhawker
I posted this question over on Honda-Tech and they said the K20 from the Si should drop right in. I guess that's what going in when the battery pack decides to go.
So, could you spell this out for a noob. If my battery goes out, what are the minimum things I need to do to keep my car moving.
Old Aug 11, 2019 | 12:13 AM
Bisoye Lookmon Ologolo's Avatar
Originally Posted by livvie
For the HCH I...you would need to:
1. You would need to remove the rear battery pack.
2. Swap out the engine with regular civic.
3. Add an alternator
4. Swap out the AC compressor (with Civic regular version)
5. Swap out the transmission (assuming you have CVT)
6. Swap out gas tank…I think the regular version is slightly bigger.
7. Swap out steering electric motor. Not sure if regular had electric steering.
Minor stuff
1. replace all the glass with regular civic glass
2. remove the rear wing lip
3. remove front air dam
4. Paint the side mirrors black
5. Paint side door moldings black
6. Replace alloy wheels with regular steel wheels and hub cap.
7. Relocate antenna (not in the middle on regular civic)
8. Replace the rear bench seat with a fold down seat.
I'm sure there is more…not sure how far you want to go to make it a civic.
Good morning sir , but honestly my civic hybrid IMA battery is on, however, whenever I input new battery and start the AC it kills the battery, so am done to be spending money, so, I want to convert to normal civic either, I was told I will buy new Engine and gear box etc for the conversion. I think the stress of hybrid is much, am using 03 civic and mileage is 190miles
Old Jun 19, 2022 | 10:55 PM
Ugbamageorge80's Avatar
Default Re: whats needed to convert from a Hybrid? Battery system to normal 75 ams
CONVERSATION of hybrid yo nomal battery
Old Jun 19, 2022 | 10:59 PM
Originally Posted by Harold
Remember these cars do not have alternators, so the electric motor charges the engine battery as well as the pack. As long as the battery is being charged and the engine and lights work you should be able to go.I would not remove anything!Hal
is it not possible for the removal of battery?
Victor123
Honda Insight
16
Oct 31, 2011 09:03 AM
pompom
Oct 27, 2011 12:23 AM
drabood
Jun 25, 2011 03:22 PM
