Spark Plugs?
It's almost time for a new set of spark plugs. Anyone change theirs yet? With what? I suppose I'll go with what the manual says (don't have it with me). Any thoughts that indexing may help MPG? I indexed my plugs on my V12, and it actually was noticable.
Just wondering how easy/hard it was on the HCH I. Wires too?
Thanks for any input.
I've heard the plugs are numbered according to how the hole in the head was threaded...to allow the gap to face a certain direction.
If this is true remember you can't put the plug from Cyl 2 into Cyl 4 etc. (Unless those two cylinders had the same number stamped onto them)
'94 Jaguar XJ12, 6.0 L V12. Gets considerably less MPG than the HCH ; )
I checked prices on the OEM spark plugs (NKG IFR5G-11K, and Denso SK16PR-L11).
They are VERY pricey! I wasn't expecting to pay ~$13 per plug!!! Wow.
I replaced my plugs not long ago. 2003 HCH that I got used. Didn’t do anything special, just replaced them. Got AC Delco equivalent to the recommended plugs from NAPA. They were a little pricy (about $8 each) but not $13! They looked the same (tapered center electrode, etc.) Didn’t loose any performance . . . may even have gained some FE, but I don’t know how old the other plugs were (I assume they were pretty old, car had close to 100,000 at the time) and how much that affected things.
kernk
kernk
Originally Posted by cbxtc6
No one mentioned there's EIGHT spark plugs on this engine (dual-plug heads).
Anyone know how to remove the 'snorkel' thingie that covers the front 4 plugs?
You will need a very long extension for your socket wrench (I put two extensions together to make a long enough one), because the plugs are WAY down in there! If you don’t have a rubber gripper in your plug socket you will never get the things out . . .
Not the coil 'thingies', but the air intake thingie.
I hope I am being of some help . . .
