ScanGauge XGuage specialty guages for first gen Civic Hybrids
I am pretty sure this is out there somewhere but I am not using the right key words in the search to trigger a meaningful response.
I have a ScanGauge and would like to know what the most useful "gauges" for hypermiling.
I know there are some "hidden" gauges. How do I get them and again which ones might be best for keeping track of the IMA battery pack.
Unfortunately that info is not in the public domain.
However I build a gauge specifically for the Insight G1 and HCH1 Hybrids which displays IMA data and allows control over the car Soc
Currently the HCH1 version displays 8 parameters.
IMA Bat Volts
IMA Bat Temp
IMA Bat Amps
IMA Bat Soc
Eng Temp
Air Temp
Fuel Inj Ms
Afr Ratio
http://www.insightcentral.net/forums...ic-hybrid.html
Several US HCH1 owners use it
IMA Bat Volts
IMA Bat Temp
IMA Bat Amps
IMA Bat Soc
Eng Temp
Air Temp
Fuel Inj Ms
Afr Ratio
Yes visit the link I posted for some details and discussions.
I also have a manual IMA control system for the HCH1 Civic and a fan controller board for a grid charger system.
All discussed and detailed over at Insight central in various threads.
OBDIIC&C G1 & HCH1 OBDII Display Command and Control Device for G1 Insight & HCH1 Civic.
I have built and tested units, minus the case etc $249
I have kits inc, programmed pic, cable, plug, lcd, components etc (Everything minus the case). $149
I have a plentiful stock of plain pcb's. $49
http://www.insightcentral.net/forums...tml#post202455
IMAC&C HCH1 Ima Manual Command and Control Device for HCH1 Civic.
I have built and tested units, inc cable, case etc $249
I have kits inc, programmed pic, cable, components, case etc $149
http://www.insightcentral.net/forums...tml#post221868
Current Hack G1 & HCH1 Ima Current Increase Board for G1 Insight and HCH1 Civic.
I have built and tested switchable +30% & +44% units, inc cable, etc $199
I have switchable +30% & +44% unit kits inc, cable, components, etc $149
I have built and tested fixed +30% units, inc cable, etc $99
I have fixed +30% unit kits inc, cable, components, etc $49
I have a plentiful stock of plain pcb's. $24
http://www.insightcentral.net/forums...tml#post155028
Fan Control HCH1 Ima Fan Control Board for HCH1 Civic.
I have built and tested units, inc cable, etc $149
I have kits inc, programmed pic, cable, components, etc $99
http://www.insightcentral.net/forums...tml#post251360
Fill your boots after reading all the info on IC.
Billyk
Alternative Fuel Vehicles
Nov 27, 2008 07:28 PM
