Repair Question....
Old Nov 14, 2014 | 05:45 AM
philwford's Avatar
Default Repair Question....
Im really having 2nd thoughts about having my car repaired...is there anyway to by pass the IMA and still charge the 12 volt....thanks
Old Nov 14, 2014 | 06:35 AM
Default Re: Repair Question....
Yes.
http://hybridautomotive.com/insight/...al/bypass.html
Gives instructions on bypass.
You will need a good DC-DC converter. You should be able to pick one up for far less than the dealer wants.
Old Nov 14, 2014 | 06:44 AM
philwford's Avatar
I guess I could have asked you in a pm..since your taking the time to reply, but maybe posted here will help others..how does the 12volt charge without IMA...
Old Nov 14, 2014 | 07:05 AM
There are 4 primary components:
1. IMA motor
2. IMA battery
3. IMA control unit
4. DC-DC converter
As long as 1, 3 and 4 are operable, the IMA system will charge a good 12V battery. There are many who choose to bypass the battery rather than deal with the expense of a replacement battery and/or are not comfortable with DIY solutions.
You can explore the components here:
http://www.hondapartsdirect.com/auto...-manual-engine
tigerhonaker
Jan 9, 2006 06:07 PM
tbaleno
Nov 9, 2005 06:50 PM
myraellen
Apr 5, 2005 06:36 PM
eak354
Apr 24, 2004 08:36 PM
