Need Help Please Read!!!!!!!
Old Apr 4, 2008 | 08:50 PM
ALE's Avatar
ALE
Default Need Help Please Read!!!!!!!
Hey, thank you for reading this. I own a HCH 03, it trembles, kicks back when i first press the gas, before it gets to 1 (on the left hand side of the circle with numbers). However after number 3 it's fine. But from bellow 1 to 2, it kicks back a lot like it's going to die, but it never does. the trembling is only when i first take off from a stop. This has been occurring for over 1 yr, getting worst each month. Gone to autoshops, and nothing. the engine light just turned on 2 mos ago, and the maintenance light is on and i just did an oil change not too long ago!!! Anyone???
Old Apr 4, 2008 | 08:57 PM
ALE's Avatar
ALE
Default Re: Need Help Please Read!!!!!!!
lknlk
Old Apr 5, 2008 | 04:16 AM
spartybrutus's Avatar
HypoFueler
Hi Alessandra - whats your vehicles VIN?
Old Apr 5, 2008 | 07:51 AM
ALE's Avatar
ALE
if you don't mind me asking, does that matter?? cuz i don't know it...
thank you
Old Apr 5, 2008 | 11:26 AM
jill.g@verizon.net's Avatar
Alessandra;
You will find it on the plate at the top of your dashboard, where it meets the windshield, or it will be on your registration
Good luck
Jill
Old Apr 5, 2008 | 12:14 PM
Gairwyn's Avatar
Think green.
The VIN could be important because it can give you information regarding any recalls that affect your particular car model/year. If your problem is due to one of the recalls, you can probably have it taken care of by Honda dealer, possibly at no cost to you. They should be familiar with some of the more common recall problems for certain year cars.
Old Apr 6, 2008 | 05:34 AM
HypoFueler
Just checking that you own an 03 HCH...
Old Apr 7, 2008 | 06:01 AM
The Great Gazoo's Avatar
Hi ALE i don't know if this is your problem but it was my problem when my 03 HCH was kicking and bucking. I had a bad EGR valve. I replaced it and it ran like a new car.
Old Apr 7, 2008 | 06:14 AM
ALE's Avatar
ALE
Hey thank you so much! i made time to take it to the dealer and see if there are any recalls, and it turned out that there are at least 3... so, and it won't be out of pocket, because they extended the warranty on the parts that needed the recall... in my case it's the transmission and some reprogramming and some adjustments.
i hope this solves my problem!!! I will keep it posted if it does, if not i think i'm going to cry, because i feel my car is going to die in any minute now.
HybridChange
Off Topic
21
Dec 8, 2008 06:20 PM
BenHCH2
Aug 26, 2006 11:21 AM
Jason
Feb 20, 2006 08:31 PM
