HCH1 IMA battery voltage reading & reconditioning
Old Sep 11, 2020 | 07:01 AM
  #31
Damian Wordofsatan's Avatar
Default Re: HCH1 IMA battery voltage reading & reconditioning
Hi guys could you please help me as I'm confused now
I have Honda civic 2007 and trying to recycle cells which are in my opinion in not as bad state
each double pack (12cells) holds between 14.8-15.8v (middle ones the least)
Now I can't take them apart to split doubles as I don't have a way to solder them back so have to charge each double pack
I've set initial numbers to
charge @5A
discharge @ 1A
cut off V @ ?
timer to 148min
cut off peak @ 5mV
capacity @ 11000mah
Could you please confirm those values and tell me what should be cut off V as I'm not sure, I believe 1Vxeach cell so 12V would be too low ?
should I then set it to 14,5V ?
Should I adjust any other values ?
Also should I just connect them to ends on plus and minus or any other way ? (I'm using imax b6)
Old Sep 11, 2020 | 07:05 AM
  #32
You can continue to cross post. I'm not going to hand you the hammer with which you'll bash your brains out for the next month. You're using a toy.
2007 Civic
Apr 17, 2026 07:25 PM
Sauto
Jun 15, 2025 01:51 PM
dosmastr
Dec 9, 2017 04:24 PM
justinuv
Aug 6, 2017 04:44 AM
John Zheng
Dec 21, 2016 12:17 AM
