HCH-I IMA and charging issues
Old Mar 29, 2017 | 05:58 PM
plauer's Avatar
2004 Honda Civic Hybrid
Default Re: HCH-I IMA and charging issues
The saga continues.
I bought a manual of eBay, good tip by the way, lots of information for $9.90.
Learned that I don't need a OBD2 tool, just a wire. "connect SCS to ground", this gives you Engine, IMA and ABS codes.
ABS: DTC 11, front right wheel sensor bad
DTC 51, abs pump motor not spinning
IMA DTC58: charge balance
DTC 66: individual cell issue
MIP DTC 12 DTC69, probably means P1269, not very clear, maybe injector problem?
Peter
Old Mar 29, 2017 | 09:36 PM
The blink codes are best used in conjunction with OBD codes.
When I have had IMA issues in the past, the ABS and MIL would report multiple issues. When I corrected the IMA issue, they all went away.
StoneJack
Aug 13, 2018 05:31 AM
theraff
Dec 5, 2015 12:01 PM
Hot_Georgia_2004
Jun 1, 2012 10:21 AM
MiaTurbo
Jan 22, 2010 06:36 AM
Mitaka
Oct 7, 2005 07:48 AM
