engine codes 1590,1585,1600,1440
Old Mar 15, 2019 | 11:49 AM
ptb's Avatar
ptb
Default engine codes 1590,1585,1600,1440
I am looking to buy a USED 2005 HCH
it has the following 4 codes.
1590
1585
1600
1440
what is the fix ?
IMA battery, computer and MCM swap ????
Old Mar 16, 2019 | 08:40 PM
Default Re: engine codes 1590,1585,1600,1440
Run away from it!
Old Mar 17, 2019 | 03:42 AM
ptb's Avatar
ptb
I have another 2005 HCH that has FLY-WHEEL damage and does NOT move, but has good IMA battery.
so buying a used 2005 HCH with a bad IMA for the swap is perfect
just wondering about these other codes 1590,1585,1440
made offer of $1536......I don't think they will accept
Old Mar 17, 2019 | 09:18 AM
P1440 IMA system problem
P1585 motor current signal problem (25 diagnostic steps)
P1590 Motor current U phase signal circuit low voltage (18 diagnostic steps)
Bad sensor, broken wire, shorted wire, bad MCM. Probably worth just swapping the entire IPU bay.
Old Mar 30, 2019 | 02:16 PM
ptb's Avatar
ptb
help me understand the components of the entire IPU bay.
i know there is the IMA battery
I know there is a computer unit next to it.
what else ?
seller willing to let go at $1600 today
Old Mar 30, 2019 | 02:23 PM
what else ?
Run!!!!!!!!!
Old Mar 30, 2019 | 02:27 PM
ptb's Avatar
ptb
I have another 2005 HCH that has FLYWHEEL issue.
so replacing IPU bay from one vehicle to the other is a RUN !!! situation ??
Old Mar 30, 2019 | 02:30 PM
ptb's Avatar
ptb
Old Mar 30, 2019 | 02:37 PM
ptb's Avatar
ptb
found this on UTUBE, looks like this is the IPU unit
take out , pop in the other ????
ok, plan to run and buy vehicle on Wednesday
bring both cars to hybrid shop and have them
swap out the IPU unit
hopefully this will zap all four engine codes
then take to shop to replace CVT fluid and burnish process
JonV
Aug 7, 2022 10:55 AM
scole01234
Dec 31, 2020 10:21 PM
Larry W Smith
Mar 30, 2020 08:03 AM
baronderpington
Jan 22, 2014 10:24 PM
lebloom
Dec 27, 2012 10:40 PM
