Which charger is best to weed out bad sticks?
Old Nov 18, 2018 | 01:45 PM
Default Re: Which charger is best to weed out bad sticks?
Yes, IPU = intelligent power unit = everything inside the cavity behind the rear seat back. IPU cover is the large sheet metal piece that covers the IPU with a dozen torx bolts.
To correct your perception, having the safety switch cover off would allow air to SUCK in through that opening instead of being sucked in from the upper deck and through the battery.
I kinda doubt that would be sufficient to cause 73, particularly with the cooler weather, but it's worth trying.
Old Nov 18, 2018 | 02:07 PM
noteworks's Avatar
Ok, its back on. I left the back seat pulled away to hear the fan run. So far, I'm getting nothing. Is there a safe place to apply 12 volts to run it? Say like a relay location? I'd like to have it run for a few minutes to check for air flow and leaks as well as hopefully cool this pack down.
Old Nov 18, 2018 | 02:30 PM
Please refer to post #5
Old Nov 18, 2018 | 02:40 PM
noteworks's Avatar
Alright, I'm assuming there's no step by step picture guides to this process (forcing the fan on) as I havent been able to locate any so far.
I'll keep looking. Thanks for the quick responses Steve.
Old Nov 18, 2018 | 02:52 PM
noteworks's Avatar
Wow, I need one of these scanners to force the fan function to test! Haha.
Sauto
Jun 15, 2025 01:51 PM
Derpguy123
Jan 3, 2019 07:07 PM
dosmastr
Dec 9, 2017 04:24 PM
S Keith
Dec 23, 2016 07:23 PM
jjh1
Feb 21, 2016 06:36 PM
