battery fan
Old Apr 24, 2008 | 08:34 AM
slammer449's Avatar
Default battery fan
Can anyone tell me at what temperature the battery fan will kick in ?
Old Apr 25, 2008 | 10:11 AM
bullet4's Avatar
Default Re: battery fan
the system contains and operation sensor that sends an output to the pcm/mcm to control fan speed and on/off. its what they call duty controlled so it doesnt come on at the same time all the time
IPU Module Fan
The battery module, MPI module, and DC-DC converter generate heat during assist/regeneration. The IPU is equipped with a fan to cool it down, assure proper battery performance, and protect the system. The fan has a control circuit and rotation sensor that are controlled by the MCM. The cooling air is drawn into the battery module from the top of the rear tray, then it is exhausted into the trunk compartment through the MPI module heat sink and the DC-DC converter heat sink.
Old Apr 25, 2008 | 02:33 PM
msantos's Avatar
Eco Accelerometrist
slammer449:
The fan can be throttled into action by the BCM's reading of the pack's temperature sensors or by another downstream module (for example the MCM or the DC-DC).
On your HCH1 the battery threshold temp should be at 90C (194F). The absolute temp trigger point for the MCM should be at 100C (212F).
Cheers;
MSantos
Old Apr 26, 2008 | 09:25 AM
slammer449's Avatar
Thank you for the response.
mhaven98
Jul 16, 2018 03:00 AM
Mojos Mom
Jul 17, 2014 12:51 AM
agunther
Jan 10, 2011 06:38 PM
Baylor Green
May 25, 2008 10:36 AM
highflyer_i469
Aug 11, 2007 02:06 PM
