Anyone replaced an O2 Sensor to correct a P0134 error code?
Old Sep 20, 2010 | 06:11 AM
kapo2004HCH's Avatar
Default Anyone replaced an O2 Sensor to correct a P0134 error code?
I had a check engine light on and it read P0134 (O2 sensor). I checked on the prices. The OEM sensor was $168 which I felt was rediculously high. I replaced it with an aftermarket sensor. I had to cut the connector off the OEM sensor and splice it to the wires on the new sensor. I had the light reset but it continues to come back on and stay on. The MPG improved so I felt the sensor corrected the issue but the light stays on. The dealer said the aftermarket sensor may not cause the light to go off because the sensitivity is so high that it must be replaced with the OEM sensor. Is that true or is the dealer simply saying that in order to sell the expensive OEM sensor?
Old Oct 10, 2010 | 11:45 AM
danboy's Avatar
Default Re: Anyone replaced an O2 Sensor to correct a P0134 error code?
I had the same issue but I got my sensor at autozone and the connector was a perfect match. I replaced it on my lunch break at work in 15 mins with and the code was cleared, no more CE light.
Old Oct 11, 2010 | 06:48 PM
Dan,
Happen to recall the part number you purchased and how much it cost?
Thanks,
Mike
Old Oct 11, 2010 | 06:58 PM
danboy's Avatar
I don't remember but I got the part number from a post here and I know it was much less than the stealer list price.
Old Oct 11, 2010 | 07:01 PM
danboy's Avatar
I do remember what caused the original to go bad. At red lights I used to FAS in the winter time before the car warmed up.
Old Oct 22, 2010 | 05:37 AM
Danboy,
I went ahead and bit the bullet on the Autozone sensor (Bosch) for $156.99. I hated spending that much on an O2 sensor but when I swapped it out and reset the error code, the MIL indicator did not reappear. Oddly enough, a week later it did reappear however it was a different error code. Two days later, it went off and hasn't reappeared since. Go figure! Thanks.
Old Oct 22, 2010 | 06:30 PM
danboy's Avatar
What code appeared?
Darby Silloway
Toyota Motor Corporation
Oct 12, 2024 10:30 PM
David Ojeda
34
Dec 18, 2020 08:22 PM
nash
Sep 27, 2013 10:00 AM
scole01234
Aug 3, 2011 01:31 PM
emdsd
Jun 16, 2009 09:12 PM
