Amsoil Synthetic CVT fluid
Old Sep 13, 2016 | 07:39 PM
IrnGynt's Avatar
Default Amsoil Synthetic CVT fluid
Anyone try it in their HCH1's CVT? Just bought my 2nd HCH1 with 96k on the clock and it's my first with a CVT and I'm scared Research is telling me these things are made out of glass.
Old Sep 13, 2016 | 09:29 PM
Default Re: Amsoil Synthetic CVT fluid
Honda Genuine CVT fluid only. Replace every other oil change.
Old Sep 14, 2016 | 05:06 AM
IrnGynt's Avatar
Any idea who makes it for them?
Old Sep 14, 2016 | 06:12 AM
No.
A CVT is no place to play around with snake oil.
Old Sep 15, 2016 | 06:30 AM
IrnGynt's Avatar
No.
Isn't it all snake oil?
Regardless, I started flushing mine last night with the manfacturer recommended snake oil and noticed some improvements. I'll continue using it until I can get some real life usage examples of the other snake oil.
Old Sep 15, 2016 | 06:42 AM
I've had an overexposure to Amsoil. Too much hype. Like Optima batteries, which are no better than Walmart, autozone or oreilleys models... all made by Johnson Controls.
I can't locate it, but honda published a research paper comparing its CVT fluid to its standard ATF that went in the HCH1. It was a back-to-back comparison of multiple parameters, and the CVT fluid was better in every category.
CVTs are unique. I'm not going against the grain on it based on the usual unsubstantiated claims or hype.
Old Sep 15, 2016 | 06:56 AM
IrnGynt's Avatar
I hear you and appreciate the input. I guess I was just hoping to get a bunch of responses like:
"As soon as I switched to Amsoil CVT fluid all my CVT wonkiness went away!"
Wishful thinking, I know...
Whatever the previous owner had in mine came out almost black. And I'm pretty sure he had it changed at some point because the fill plug was loose. Like less then finger tight loose.
Old Sep 15, 2016 | 08:10 AM
Unfortunately, no. While I've not heard about Amsoil specifically, others have tried other brands of CVT fluid, and all accounts were a worsening.... shuddering, a firmer hit when the start clutch engaged, slipping, etc.
In my experience, the CVT produces a lot of fuzz... finer than is typical for an automatic. The belt to pulley contact is all metal-to-metal. The fluid darkens quickly to a reddish-brown.
Given your description and the lack of specific data concerning fluid change intervals, I would recommend 3X fluid changes over 3 weekends with a week of normal driving between. IIRC, the CVT holds 5.7qt total. With only draining 3 qt, you're only replacing a little over half. After 3 changes, you'll be at 85.4% new fluid.
From there, it's every other oil change or 12-15k miles.
bwilson4web
Jul 8, 2009 05:20 PM
UWAdventurer
Nov 30, 2008 04:28 PM
kenkobra
Oct 1, 2007 11:51 AM
atikovi
Dec 22, 2006 11:40 AM
