'05 HCH CVT rumbles on acceleration
Old Feb 20, 2012 | 10:29 AM
clayk's Avatar
Default '05 HCH CVT rumbles on acceleration
Haven't posted here in a LONG time. Recently my '05 HCH CVT, 72,000 miles has started to make a "rumble" from the front end when I accelerate from a stop. Worse when going uphill, hardly noticeable when going downhill. Is this the symptom of the CVT clutch problem that was under a recall and would I still be eligible? Thanks for any help.
Clay
Old Feb 20, 2012 | 11:17 AM
Gairwyn's Avatar
Think green.
Default Re: '05 HCH CVT rumbles on acceleration
Yeah, that sounds like the usual symptoms. Have you had the transmission fluid changed? Honda CVT fluid is the correct one to use. Sometimes that helps.
Other than that, here's some info regarding the start clutch, and there are several threads here if you do a "search".
http://www.fileden.com/files/2010/4/...h%20Judder.pdf
There's also another service bulletin regarding CVT drive belt slippage, that's service bulletin #07-050
Old Feb 20, 2012 | 11:31 AM
clayk's Avatar
Seems like I did at 50,000 or so during routine maintenance. If it is covered by the recall I would hope I would be covered
Old Feb 21, 2012 | 06:45 PM
Gairwyn's Avatar
Think green.
You're probably covered; I'm not sure if it goes by the date of first purchase or the date of manufacture of your car, but hopefully you still fall within that time frame.
simply2crazy
Dec 19, 2011 06:23 PM
prairieclover
Apr 3, 2009 05:36 AM
UWAdventurer
Nov 30, 2008 04:28 PM
jstreff
Jul 23, 2007 03:57 PM
Inigo Montoya
Jan 24, 2006 02:03 PM
