Upgrading to Rosen Nav Head Unit and rear view Camera
Old Aug 28, 2011 | 12:07 PM
Time Hybrid's Avatar
Default Upgrading to Rosen Nav Head Unit and rear view Camera
Hi guys,
I bought a 2011 Silverado Hybrid planed on some upgrades.
1st was the Head unit and rear view camera.
The truck came with the basic head unit, and after research, I decide for a Rosen Nav Head Unit. Also got a GM Rear view camera kit for completing the set up. Head Unit also came with Ipod/Iphone cable, Video Capability, better equalizer options for the OEM Bose Speaker system.
And it looks almost the same as my other truck High end Delphi unit, but performs so much better !
Got some pics of the installation.
Everything went smooth, and all my steering control buttons work flawless. Rear camera works great, and just like in our hybrid tahoes.
Also, didn't have to go to the Dealer for a re-flash to make my rear view camera work.
Location is in the Rear tail gate handle.
Old Aug 28, 2011 | 07:28 PM
LakeSilverado's Avatar
Default Re: Upgrading to Rosen Nav Head Unit and rear view Camera
Nice pics.
What is the model number of the head unit you used?
Old Aug 28, 2011 | 08:05 PM
Thanks, I have to take pics also of the rear camera.
This is the part number of my unit.
DS-GM1010-P11
Not For Bose
Centerpoint
Old Sep 5, 2011 | 06:50 PM
hog66's Avatar
Hi Time Hybrid,
I have been thinking of purchasing the same head unit but unfortunately, I can't really find a lot of info about it online. One question I have is about the USB functionality. I noticed that you removed the USB port in your center console and routed the ipod cable through there. Did the unit not connect to the existing USB port? Also, do you know if there is a limit as to how big of a USB drive the unit can read? Thanks.
Old Sep 5, 2011 | 09:41 PM
hog66,
Welcome to the site.
Regarding the USB functionality, I just can tell you my personal experience. I have no idea About the limits of the USB capacity manager. Maybe been a Windows CE based unit, could be +64GB, but that is pure speculation.
Now the facts. The head unit doesn't have an USB port on the back, so I was unable to connect the OEM stock USB cable to it.
Final install have stock USB and IPOD connector living inside the center console. But USB connector is useless. Need to take pics of that too.
The only USB port of the head unit is on the Front and came with a converter cable. I use it to charge my BlackBerry device. It reads the micro SD in my BB (32gb SDHC) and plays the music, pics, not the videos.
Ipod/Ipad/Iphone interface plays Music and videos.
Front SD slot also been tested with my GoPro 32gb card, just played pics, not video.
Haven't played more with this inputs. I use the Ipad function and DVD's a lot more.
So there you have my Experience in the USB port.
Hope that helps. Sorry for not having more info for you.
If you need any other info, chime in. I will try to make my best based on my personal experience.
Regards
Old Sep 8, 2011 | 09:17 PM
hog66's Avatar
Talking Re: Upgrading to Rosen Nav Head Unit and rear view Camera
Time hybrid,
Thanks for the response, I've thought of a few more questions for you. I generally do as much research as I can before I buy something and this thing is so hard to find any real documentation on so finding someone that actually has one is great. Okay, so here are some questions that I can think of now:
1) In your post you said that the front SD card slot was tested with a 32GB card with pics, I'm assuming it works fine for music files too?
2) Does the truck have to be in park to use the nav system?
3) If you use the Rosen bluetooth (instead of the built-in), does it read your contacts? I'm assuming yes since I've heard somewhere it has A2DP functionality?
4) And finally is there anything that really stands out to you good or bad about the features and interface or anything in general? (yes, I know that's a loaded question )
Thanks!
Old Sep 9, 2011 | 10:37 AM
1) SD reads all files minus Video.
2)The safety feature mandates to be in parking for Video Views, not Navigation.
I bypass that safety, and I can see movies on the go.
3)The Rosen Bluetooth is like any A2DP unit. It links your music, your adress book and all the stuff, but I turn it off. I use the GM bluetooth
4) Pros: Real Plug and play unit
Video capabilities.
Lot of sources for music.
Excelent sound control
Cons: Wish usb port on the back to retain my oem USB conecction.
In sources don't manage video, I wish the would.
No more cons so far !
Old Sep 12, 2011 | 05:27 PM
hog66's Avatar
Time hybrid, thanks for the info. I hate that you lose the console USB port but I guess that's okay if the SD card slot can read at least a 32 GB card. I think I know what I'm getting for christmas now! BTW, I've read somewhere in all my Google searches that you can get Garmin to run on it since it's a windows CE based program. Anywho, thanks for the help.
Old Sep 12, 2011 | 05:41 PM
HyHoe's Avatar
aka soulsea
That's a really clean install TH.
I'm actually surprised that the Silvy Hybrid doesn't come stock with the GM nav unit, but that's probably a good thing considering the pos that it is.
I wonder though, does the Rosen display the hybrid/2mode drive screen?
Old Sep 16, 2011 | 03:20 PM
Yeah, I can install Garmin.
Go to Prius hybrid Forums, There are tons of Rosen Units installed there.
They have install the Garmin Software and maps no problem.
