Time for a Battery for 08 Tahoe with 205k miles
Old Jan 22, 2020 | 10:25 AM
dawgfan1606's Avatar
Default Time for a Battery for 08 Tahoe with 205k miles
I am planning to let my kid drive the HYHO when she turns 16, in a few months. However, the quirks I deal with, I don't want her to deal with (stalls from a stop, lurching at low speeds, sometimes not braking properly). It's time to replace that big battery as they aren't getting any cheaper or easier to find. I've read most of the battery posts over the last several years. Am I ok, with a refurb...yes because I just want to run the HYHO until it falls apart as a 3rd vehicle.
S_Keith - do you sell modules? I am capable of tearing that pack apart and installing 40 modules.
Greenbean seems like an OK choice for my need and they are now giving an 'unlimited warranty'.
Has anyone used or seen the hybrid battery Summit Racing sells - it's basically the same price as Greenbean with a 3/36 warranty, but it is Summit Racing? I can pick that up here in Atlanta
Thanks,
Tony
Old Jan 22, 2020 | 11:20 AM
Default Re: Time for a Battery for 08 Tahoe with 205k miles
No. I do not. Do what Jaime did. Source two low mileage Prius C packs for about $2K. That will be better than any offering from anybody else unless it's new from GM.
Old Jan 22, 2020 | 11:22 AM
Thank you!
Old Jan 22, 2020 | 02:54 PM
Tahoe_08's Avatar
if it's not braking correctly i would have them inspected
when the dealer sold the crap one on the lot the rear brakes did not work at all tell one day it fully locked up when I was going 55mph (had a green light hence going that speed)nearly causing an accident with 2 other cars.. luckily it happened on a off ramp if it would have happened 30 seconds earlier it would have been a pile up on the freeway with some 18 wheelers and many cars...i was going 75mph then...
if they are ok I would have the 12volt battery and cables replaced... the 08/09 had a design issue that allowed the cables to come loose overtime .. this is why people that replaced the transmission AUX pump placebo effect of it being "fixed" as the cable was re-secured to the battery after the pump being replaced (they disconnect the 12v & HV battery before working)
aka auto stop lag resume...
I got to replace mine as well but i just temporarily fixed by soldering the connection.. where i had the issue
Old Jan 22, 2020 | 08:13 PM
BamaPaul's Avatar
dawgfan, I'm in auburn and in need of a battery rebuild as well. If we find 3 prius packs we can cut cost some and build two batteries.
Old Jan 23, 2020 | 07:49 AM
You're likely going to pay a huge premium for Gen4 Prius batteries, which may or may not result in savings.
Do not purchase packs with > 30K miles on them. Do not purchase packs from models prior to 2016.
Old Jan 25, 2020 | 09:10 AM
I haven't had a chance to look at the battery cables. Are they just normal 12v battery cables on the hybrid?
Old Jan 29, 2020 | 04:59 AM
not sure if it applies to you. just have it replaced by the dealer. they will give you full replacement 12 month warranty which is worth it.
Old Jan 29, 2020 | 05:59 AM
Hillbilly_Hybrid's Avatar
I recently checked and the price the dealer pays now is more than yours cost on your 2009 Exky. Over $4k list. Ouch! But it is a way to get all new good cells.
Old Jan 29, 2020 | 06:08 AM
Yup, dealer gave me $3600 yesterday. Now, the truck has been running great in this 30* weather. Maybe I can rig up a cry-cooler for all the hybrid components
