Tahoe/Yukon Hybrid Problems: Brake Loss, Service Traction Control,Service Stabilitrak
Old Apr 12, 2014 | 02:49 PM
  #151
JetMech's Avatar
Default Re: Tahoe/Yukon Hybrid Problems: Brake Loss, Service Traction Control,Service Stabili
Yep. Just got it again
Old Apr 12, 2014 | 02:59 PM
  #152
JetMech's Avatar
I give up ...
Old Apr 12, 2014 | 03:01 PM
  #153
jimr5454's Avatar
It's a 08 correct? Any codes showing up?
Old Apr 12, 2014 | 03:55 PM
  #154
One way to find out is eliminate the MC by replacing it since you said the codes points to nothing
Old Apr 12, 2014 | 09:34 PM
  #155
Hillbilly_Hybrid's Avatar
Some of those codes could be from bad bleed. The 08s were a pain to get the bleed right.
Old Apr 13, 2014 | 02:47 PM
  #156
JetMech's Avatar
That's interesting hillbilly. Sometimes I've thought that could be it.
Old Apr 13, 2014 | 03:25 PM
  #157
How many miles? Sometimes eventual failure has happened due to stop and go use of the brake pedal..
Old Apr 13, 2014 | 03:34 PM
  #158
jimr5454's Avatar
How often would u need to bleed brakes ...not on pad changes ...right ?
Old Apr 13, 2014 | 03:48 PM
  #159
Never. I use a pad spreader and replace with new pads.
Old Apr 13, 2014 | 04:43 PM
  #160
Dealers were not ready for many of the new systems in hybrids. Some still are not. The 08 has many more pressure sensors in the main brake module ( under the driver's seat ) under floor that later models don't have. If that system has been opened and or improperly adjusted, the system can and usually does act up. There are very fussy procedures for the bleeding of hydraulics and calibration of the sensors. If either had been done in the past, a re-do by an experienced dealer may be in order. Either way getting the technical line folks to help should minimize just Easter Egg hunting for the problem. Before swapping expensive parts, have more than a guess on your side.
