tahoe hybrid runs for 10 secs and dies
Old Jan 10, 2024 | 04:32 PM
candrade85's Avatar
Default tahoe hybrid runs for 10 secs and dies
Hello, tahoe hybrid 2010 owner here. truck was running great. today i started it and 10 secs later rpms began to drop and finally died. tried to fire it up again, same.
service hybrid system, service power steering in the dash.
scanner shows codes P1A1F And P0BBD under hybrid control module. no codes for power steering unit.
SOC 57.418%
is my hybrid battery dead?
Old Jan 10, 2024 | 06:12 PM
Default Re: tahoe hybrid runs for 10 secs and dies
The fact that it spins suggests it isn't, but P0BBD strongly indicates excessive block voltage deviation. IIRC, P1A1F is love HV voltage.
What are the min/max block voltages.
Running for 10 seconds typically suggests the hybrid battery is spinning the engine, but it's not firing for some other reason.
Old Jan 11, 2024 | 12:29 PM
???'s Avatar
yep, I've seen posts about it before. since the motor in the tranny spins the engine over to start it, unlike a normal stater. it seems like the engine is running on its own but it's not. check normal car stuff like fuel pressure and spark first. make sure the ecm is getting an rpm signal if you have a scanner, stuff like that.
Old Feb 7, 2024 | 10:37 AM
???'s Avatar
Originally Posted by chima lecci
How did you figure it out ?
chances are they didn't.. most people end up trading them off when issues hit.
is yours doing the same thing?
Old Feb 7, 2024 | 10:56 AM
Not sure if you noticed, but this is all this person does on multiple models. They usually also have a spam link. Best to ignore.
https://electricvehicleforums.com/fo...earchid=397733
Old Feb 7, 2024 | 06:49 PM
???'s Avatar
ahh they got me.. I missed the spam link in the post.
Old Feb 18, 2026 | 07:11 AM
sepmaret11's Avatar
My coworker waited weeks for a used transmission for a hybrid Tahoe. It finally showed up and he tipped it up and water ran out of it for a solid 60 seconds
AIsaacs
General Motors Corporation
10
Oct 27, 2022 05:14 AM
Dylan06CivicHybrid
Jun 30, 2022 12:05 PM
utspg
Jan 8, 2016 04:00 PM
sandykor@sbcglobal.net
Dec 1, 2009 02:50 AM
rpfleming
Jun 2, 2009 08:46 AM
