Stalling Problems 2008 Yukon Hybrid
Old Apr 8, 2015 | 08:18 PM
Hillbilly_Hybrid's Avatar
Default Re: Stalling Problems 2008 Yukon Hybrid
Did the dealer also get the Freeze Frame data with the code? That code could be a symptom of a totally unrelated problem.
The dealer scan tool can also record data from the truck.
Old Jun 18, 2015 | 01:23 PM
Jolo's Avatar
I have exactly the same thing, they were almost doing the 300v batterie, they didn't bucase they didn't have enough proof, because I was at the dealer almost every week and my suggestion from the representative was to get rid of it.
Old Jun 18, 2015 | 05:51 PM
You need to find a dealer that actually knows a great deal about hybrids.
These are complex vehicles and NOT to be poked around with by ametures.
If it is stalling there will be more codes. There will be Freeze Frames that a dealer scan tool can obtain. Then you can begin to diagnose the problem.
The scan tool can capture Snap Shot data that can be analyzed by GM people to help. It sounds like you have someone who would rather hope that the problem or the customer goes away.
Stalling without warning can be a big deal. Someone needs to take this seriously.
Old Apr 10, 2016 | 07:17 PM
Piznutch01's Avatar
I bought a 2008 gmc hybrid yukon also amd itoo am having issues with stalls, surges,and the endive revving up. Had anyone found anything concrete yet? I don't believe it to be a fuel pump as evois suggests but i am certainly no mechanic
Old Aug 17, 2016 | 08:09 PM
greenfreek's Avatar
having same issues posted ...any updates/fix ..much appreciated
Old Aug 18, 2016 | 08:56 AM
Check the hybrid battery in the dealer. Get a code from their diagnostic tools.
Old Aug 18, 2016 | 09:00 AM
greenfreek's Avatar
I got those on my obd freezeframe: any ideas? i googled them and got zero info
-P0AC4: Hybrid Powertrain Control Module Requested MIL Illumination (Powertrain, Generic)
Permanent Diagnostic Trouble Codes
-none
Freeze Frame
-P16F9: ISO/SAE Reserved (Powertrain, Generic)
-Calculated engine load: 0.0 %
Old Aug 18, 2016 | 04:23 PM
Does it start and run? Have you cleared codes and re-tried?
Old Aug 18, 2016 | 05:57 PM
greenfreek's Avatar
yes, it starts and runs, cleared codes, came back, so did the stalling,
happens when coming out of full stop (say a red-light) and then as i press accel. the darn thing makes a jerk and stalls!
its not at every stop but if i drive it for an 1rh or so, it will do it maybe once or twice...enough to be dangerous i'll say
Old May 10, 2017 | 06:55 PM
ten924s's Avatar
I am not sure if this will help anyone, but I purchased a 2008 Yukon hybrid in October of 2016 with 75,000 miles. In February of 2017 I noticed that my Yukon was driving weird. It would act like it would stall when I tried to accelerate and brake plus it always felt like I wasn't quite in gear. RPM's would go crazy and then the worlds loudest noise was coming from the front. I never had the check engine light come on, but I took it to a local GMC dealership here in St. Louis and was given the news that I needed to replace all 8 lifters and the cam shaft. The quote was over $8000!!!! Well, I ended up getting the work done somewhere else for $5000 and thought I was set. A week after getting my truck back the hesitation was getting worse. It actually would stall WHILE I was driving and I couldn't get power when going uphill. Took it too my local AutoZone because check engine light came on for the first time. They couldn't pull any codes and they tested the battery which came back good. I decided to try my luck at the Chevy dealership a mile away from my house. They informed me that I had the wrong type of battery in my Yukon hybrid and although it was "good" it wouldn't supply the power I needed. So they gave me employee pricing on getting the right battery and $200 later my truck is running just fine! So I would suggest that if you are having the same type of issues to double check that you have the right battery in your truck and if you live in St. Louis, Mo go to the Jim Butler Chevy dealership in Fenton. They were more than wonderful to deal with!
schmen
56
Sep 22, 2022 08:04 PM
cessy1
33
Mar 19, 2021 02:38 PM
Defender
190
Feb 18, 2021 06:05 PM
hmkinms
Jul 22, 2010 10:50 AM
Guss
32
Dec 26, 2009 07:23 AM
