Smoke at start up
Old Aug 8, 2017 | 08:15 AM
PRYUKON2008's Avatar
PRYUKON2008
Default Smoke at start up
Hey I was wondering if anyone can tell me what could be causing my Yukon to blow out a huge cloud of a white/blueish color smoke from my exhaust when I first start up in the morning. After that it doesn't happen the rest of the day. This just started on Friday, I do have 202,000 miles,
Old Aug 8, 2017 | 08:46 AM
Default Re: Smoke at start up
white is coolant.
blue is oil.
Look for a reduction in levels of both. Check cold every morning.
I would suspect weeping head gasket for coolant and valve guide seals for oil.
Old Aug 8, 2017 | 11:10 AM
PRYUKON2008
What am I looking at cost if it is those two things, is worth the fix if the truck has over 200,000 miles?
Old Aug 8, 2017 | 11:18 AM
No idea beyond "not cheap"
Old Aug 10, 2017 | 12:18 PM
Hillbilly_Hybrid's Avatar
Sounds like classic Valve Stem Seals to me. Been a Small Block Chevy "feature" for decades.
If it is you should have measurable oil consumption. So how far on a quart?
Like S Keith said, is coolant disappearing?
If it is stem seals, the Catalytic converter is NOT hot on the first start of the day.
Also, if it is Stem Seals, it's relatively CHEAP. Shop air into the spark plug hole and an over-head valve spring compressor
All subsequent starts a hot Cat masks a multitude of sins.
We had a suburban race boat hauler that would fog real good at the motel in the morning. The rest of the time towing no smoke at all.
Only the morning fog.
Old Aug 22, 2017 | 05:14 PM
Baranfin's Avatar
My engine would blow a slight puff of smoke on cold start as well, turned out I had no(low) compression on 2 of my AFM cylinders. Do a compression check on your engine I would suspect oil fouling as it is a common problem with these AFM engines.
Old Nov 18, 2018 | 07:48 PM
dnt1010's Avatar
Valve stem seals all the way on a Blue Smoke cold startup. Indicates that other areas of the engine also probably have substantial wear.
Drop in a new crate engine and make sure you only run synthetic and change oil at 50% OLM and you should get another 300k out of your rig easy.
Haha it is easy for me to Spend OPM (Other Peoples Money) just messin with U. I would just drive it until it starts fouling plugs then have the heads pulled off and rebuilt.
The Blue Smoke works great in the summertime as a gnat smoke. Do you have yuppie neighbors that will be offended by your tailpipe smoke?
nash
Mar 2, 2014 01:49 PM
n8kwx
Apr 8, 2013 08:34 PM
hmkinms
Jul 22, 2010 10:50 AM
nash
Aug 13, 2007 04:03 PM
06hch2
Feb 7, 2007 07:33 PM
