Power Brake Problem?
Old Jun 25, 2010 | 11:26 PM
  #41
Default Re: Power Brake Problem?
Originally Posted by xfordguy
The dealer has been replacing parts as instructed by GM for nearly a month now. They can consistently reproduce the brake failure using the steps I listed above. I takes a minute or two, but they keep failing.
I have a feeling GM is buying a lemon from me very soon.
or they don't know how to troubleshoot it. I'll see in my service manual if there is anything about it.
Old Jun 26, 2010 | 04:25 PM
  #42
xfordguy's Avatar
I appreciate the thought, but I wouldn't bother. Even the dealer is getting tired of being told what they have to do. Their opinion on what is wrong doesn't seem to matter they can only do approved repairs.
I couldn't believe GM made them spend $750 on a special hybrid brake bleeder, which didn't help. They also replaced a caliper for no reason this week.
In a few days, it qualifies as a lemon in this state.
Old Jun 26, 2010 | 06:18 PM
  #43
my guess is if is just an air bubble in the system. a tech not worth his salt will not bleed it propwrly even if they get the gadget.
Old Jul 3, 2010 | 12:27 PM
  #44
xfordguy's Avatar
I got the truck back yesterday. It even stops!
The story was amusing. The GM telephone tech that was working the case went on vacation, the next guy let the dealer change the part they thought was the culprit. It was a valve that they could hear hissing when the brake was pressed. This seems to have cured the failing brake issue.
The weird thing is the brake pedal doesn't feel anything like it did before the problem. The old pedal was solid as a rock and nothing could move it down very much. Now, it feels fairly solid, but if you really stand on it, it moves down a couple inches and then stops. The pedal also goes down to the "lower position" if you are holding it when you start the truck. When the pedal is as far down as it can go, I can hear a faint buzzing sound.
Since it is possible I've had a problem since the truck was new, I have to ask "Do they all do that?".
Old Jul 3, 2010 | 03:45 PM
  #45
since the power assist(servo) brake pedal sinks a little when you start the vehicle, I'm surprised that it does it also with the hybrid since it is electric assist. so, yes they all do that.
Old Jul 3, 2010 | 09:01 PM
  #46
xfordguy's Avatar
Odd that it didn't do it when new. If I let go of the pedal, it springs back up and feels normal, unless you push hard. Does everyone's hybrid let you push through the "first" place the pedal stops at, as well?
I wish I had driven more than one GM hybrid before I bought mine. There aren't any more in town, or I'd go for a test drive to see. This dang thing is really troubling.
Old Jun 23, 2011 | 11:43 AM
  #47
Steve O's Avatar
This exact same problem did happen to me. The dealer reflashed the program and it operated normally afterwards.
Motown
General EV Discussion
17
Jul 21, 2016 03:09 AM
Eggsaladsndwich
Feb 10, 2014 04:48 PM
lars-ss
Off Topic
Jan 24, 2010 07:48 PM
jurdean
Oct 26, 2007 01:53 PM
