POBBD " Hybrid battery pack voltage variation exceeded limit"
Old Feb 18, 2016 | 05:08 AM
Keep us updated.
Old Feb 18, 2016 | 01:55 PM
CaddyHy's Avatar
Default Re: POBBD " Hybrid battery pack voltage variation exceeded limit"
Originally Posted by evois
Keep us updated.
Sure will!
Old Mar 15, 2016 | 06:50 PM
Beaten Path's Avatar
I just recently got those codes plus some others at 84k miles. I'll have to look at my service receipts for the others.
When I took my 08 tahoe hybrid to the dealer, they said my auxiliary transmission pump was bad and that the hybrid battery might be bad as well. but i'd have to fix the former before they could check the latter and replace it under warranty. So I had the aux trans pump replaced (with the 2009- version). The dealer then test drove it and no check engine light came on. this meant they could not replace the battery under warranty. so they gave the truck back to me noting that the CEL may come back on. After about a day, the CEL came on again. Took it back to the dealer and they diagnosed a bad hybrid battery. Now I have a brand new one, free of charge! I believe the battery changed in 2009 so I"m hoping I see some mpg improvement.
I know there was an additional code that meant a brake switch was bad so I had that replaced as well. I'm hoping all of this will also mean the elimination of my lurching/hesitation issues.
Old Mar 16, 2016 | 04:39 AM
8 years/100,000 miles in all hybrids.
Old Nov 7, 2016 | 10:04 AM
dc100's Avatar
Did you ever find out the issue?
Old Nov 7, 2016 | 12:56 PM
Hillbilly_Hybrid's Avatar
P0BBD is bad and requires follow-up. A good tech can use the GM scan tool to narrow it down to one of 2 cells in the battery.
Frank Wu
Jun 20, 2015 06:13 PM
Mark E Smith
Nov 2, 2007 10:38 AM
Delta Flyer
Off Topic
Dec 25, 2005 11:24 AM
Jason
Our Announcements
Sep 28, 2004 02:53 PM
Jason
Our Announcements
May 21, 2004 11:38 AM
