No start, need advice
Old Apr 3, 2022 | 05:32 PM
Turbotalonx's Avatar
Default No start, need advice
2008 tahoe hybrid.
Problems started with a bad fuel pump. Changed out the pump and everything was fine. Drove around the block a few times and it died. Hooked a tow strap to it and brought it home. Loosened up the gas cap and it started back up. Pulled the tow strap tight over the hood and into the door. Drove around the block and the strap slipped off the hood. As soon as the strap caused the front left tire to stop, the truck died. Now it doesn't attempt to start. I believe it says the interlock circuit is interrupted or something. The big fuse is good. The plug on the hybrid battery is installed. The switch under the hood by the passenger side is still correct also.
I have searched for weeks now and can't find anything to help. I've pulled every fuse I can find and checked them all. I've replaced the 12v battery.
The hybrid battery is still good as far as i can tell.
I have autel and tech2 clone to use for scanners.
any help is appreciated
Old Apr 3, 2022 | 06:26 PM
Jaime's Avatar
Default Re: No start, need advice
Make sure the battery disconnect plug is fully inserted and you slide the handle down after inserting it, otherwise you will continue to get that interlock message.
Here's a video that shows the safety plug being removed/installed. Different car but same type of battery and plug
You can see that the handle part of the plug slides.
Old Apr 4, 2022 | 06:06 AM
Here's a video that shows the safety plug being removed/installed. Different car but same type of battery and plug https://www.youtube.com/watch?v=NQHFswd0ggo
Would the thing that happened with the strap have anything to do with this plug? I unseated it and replaced it after hoping for a kind of reset. It is seated like in the video now.
Old Apr 8, 2022 | 07:39 PM
???'s Avatar
did it work? there's another thread that just ended from a guy that hit a big pot hole and his died. don't know if he got it fixed either.
Old Apr 12, 2022 | 11:03 PM
Tahoe_08's Avatar
most likely it set off the crash sensor
Old May 22, 2022 | 09:33 PM
No fix as of yet
Old Jul 2, 2022 | 07:48 PM
dnt1010's Avatar
You probably figured it out by now but Yeah you set off the HV crash detection module it has to be rest with a tech2 or equivalent. Did anyone get video of the tow strap incident that would probably make that TV show "funniest videos"
ioimparo
May 23, 2006 08:21 AM
davidlevner
Oct 30, 2005 11:26 AM
suhaildesigns
May 2, 2005 11:20 PM
