New owner of 2010 Yukon Hybrid - Have question
Old Nov 12, 2016 | 06:58 PM
Curlyp's Avatar
Default New owner of 2010 Yukon Hybrid - Have question
Hello Community!
I just recently purchased a 2010 Yukon Hybrid about 30 days ago from the south. I purchased it with 113,600 miles. The Yukon drives and looks great. I even had it fully look by the Hybrid tech at my GMC dealer and he found no issues. The tech told me the engine and transmission look "dry" (no leaks), and that the underneath of the car has no rust from being in the south (he let me see it as well).
The Yukon did not come with with roof rails on top. I would like to have them installed so we can use the Hybrid Yukon for a vacations over our non-hybrid Yukon that has roof rails. Do you see any issues with having roof rails installed? Is there a reason why they were not installed. If I did have them installed, will it ruin my gas mileage, hybrid driving, etc?
Thanks in advance!
Old Nov 13, 2016 | 09:33 AM
Hillbilly_Hybrid's Avatar
Default Re: New owner of 2010 Yukon Hybrid - Have question
If you search around here on many older threads, you will find folks who put roof rails on.
You will NOT be able to measure any fuel economy change from them. Depending on what you put up there and how fast you drive... that's another story.
Old Nov 13, 2016 | 11:49 AM
Curlyp's Avatar
Thanks for the information. I will search around. By the way, do you know if any of the hybrid cables run through the roof? I'm worried that drilling in the roof could splice one of the cables. By the way, the bodyshop is going to use a well-nut. He told me that the well-nuts help with sealing to prevent water leaks. Also, he's going to use sealant on the screw and inside the well-nut. Once it is crimped together, it should be sealed well.
Old Nov 15, 2016 | 08:36 AM
Nothing up there but Heat AC and dome light wires.
GreenMach1ne
Introductions
Apr 15, 2013 08:55 PM
clayton4115
Jul 6, 2012 12:03 AM
Alster
May 30, 2010 07:19 PM
jet1
Oct 28, 2009 05:52 AM
stevenvillatoro
Honda Insight
Apr 28, 2009 07:40 PM
