interesting no start issue
Old Jul 1, 2011 | 08:41 PM
jet1's Avatar
FLY NAVY!
Default interesting no start issue
my 08 yukon wouldn't start the other day .... of course we were going on a trip and it was saturday. tried all sorts of things incl jump start but the car was totally dead.
i give up and call for a tow after much @#####@$%^ the truck gets there and I figure i should push it out in the driveway a bit. put the key in, shifted to neutral out of park and then just for a laugh I tried to start it again......OF COURSE it started right up in neutral!
I am assuming there is a micro switch out of adjustment when its in park however it hasn't happened again. waiting for the next oil change to see if my thoughts are correct.
just a handy hit at this time.
Old Jul 1, 2011 | 10:37 PM
Default Re: interesting no start issue
I realized no gas causes a no start issue also.
Old Jul 2, 2011 | 02:01 PM
KC135R's Avatar
There are a number of things that could cause a no-crank condition. Since you didn't mention it, I take it there were no malfunction lights or message on the cluster during the crank attempts or subsequent restart? Might be worth a trip to AutoZone to sign out a code reader and pull codes.
Old Jul 2, 2011 | 04:26 PM
jet1's Avatar
FLY NAVY!
Default it was TOTALLY dead
no chime with the key in .... no crank....no nuthin! its under warranty so I will just let the dealer fix it,,,sure was odd though
Old Jul 11, 2011 | 06:05 AM
Hillbilly_Hybrid's Avatar
12V ignition feed issue??
Old Jul 13, 2011 | 10:37 AM
jet1's Avatar
FLY NAVY!
terminals looked ok and were tight and clean so it would have to be downstream,,,,maybe a relay but that doesn't explain why it started in neutral but was completely dead in park thanks for the other thoughts i'll explore a bit more
MyPart
Nov 4, 2009 02:12 PM
krousdb
Oct 22, 2005 11:49 AM
Jason
Off Topic
Aug 4, 2004 04:36 PM
Jason
Off Topic
May 28, 2004 09:33 AM
