Help with harness
Old Dec 30, 2022 | 07:23 AM
Dustinlint's Avatar
Default Help with harness
So anyone who's been following here's an update. The motor I got from the junk yard had a knock as well
... go figure .. so I ripped it back out and rebuilt from the bottom up. Everything. Sprang for Acdelco lifters new pistons had it honed all in all im about 4500 into the engine... now it's been sitting a while and naturally things were moves around n now I'm a bit lost. Mainly with the routing of the harness. Can someone take pictures of where e erything goes. Like how the we ecm is bolted where the aux pump cables go and all that. Hooking up the harness is the very last item. Otherwise it's all back together. I attached a photo of the engine showing new pistons and all cleaned just for fun
Old Jan 1, 2023 | 04:41 PM
???'s Avatar
Default Re: Help with harness
looking good. I snapped some quick pics of mine but when I got inside and looked at them, I don't think they will help much. but here's 2. I can try to get some more specific ones for you if you need.
Old Jan 1, 2023 | 10:38 PM
Dustinlint's Avatar
I appreciate that. It helped. So apparently I may have a broken wire here somewhere. My Serial gateway data module doesn't come online. I can't access it in my scantool. I've checked all fuses multiple times. Any thoughts?
Old Jan 2, 2023 | 01:52 AM
???'s Avatar
off the top of my head there's a thread somewhere about that thing. I'll to find it. I think the module is under the dash? it might have failed and not be a wire issue.
Old Jan 2, 2023 | 11:11 AM
???'s Avatar
it's a long thead and I'm not sure it's helpful for you, but this is what I was thinking of.
https://electricvehicleforums.com/fo...3-yukon-31738/
it's on the can bus network, so if you can talk to everything else. it might be the module itself is bad? just a guess. I might be about to find a pin out for it if you think it might help.
Old Jan 2, 2023 | 11:34 AM
Dustinlint's Avatar
it seems like these people are still able to drive their cars. Mine will not start.
Old Jan 2, 2023 | 12:52 PM
???'s Avatar
ahh I didn't know it wouldn't start. yeah this seems like more of an annoying light than something that keeps it from running. I don't know what all that module actually does. you're definitely deeper into this platform than me. all I could ask is the simple stuff like is the 12v battery charged or hybrid voltage up. codes and things. hopefully it's just a missed plug or something.
Old Jan 3, 2023 | 12:55 PM
scotttheengineer's Avatar
Found it!! This is the cable going to ECM. PLugs are just out of frame.
My cable going to bottom of ECM is either loose or Rusted. I'm losing comms on my bus. Also my Aux Trans pump is whining So I'm looking at replacing that too.
Got this from a post at another forum today.
Just in case anyone comes looking the hybrid use a E67 ecm module (three plugs). It is under the small fuse box next to the battery. You must pop the top of the small fusebox off then take off three screws that hold on the bottom half of the fuse box. Then you have to push on the top two tabs to release the ECM. The wires are to short to release the three plugs from up top so I will probably have to do it from under the car.
jmorton10
Nov 18, 2009 06:45 AM
phil94
Saturn Vue Green Line
56
May 10, 2008 10:58 AM
rdinatal
May 8, 2007 12:09 AM
cherokee180c
Jan 28, 2007 11:47 AM
HoslerD
Oct 14, 2006 04:37 AM
