first recall...
Old Jul 30, 2009 | 10:29 AM
fjungman's Avatar
Default Re: first recall...
Just to keep you calibrated, I live in San Diego, so it is hilly, but even with a slight upgrade, I can get to 30MPH before the ICE turns on. It is VERY sensitive to "tip-in" (initial throttle application) when standing still, but past about two MPH, then it can take a little more throttle and swoosh (ok, that is a stretch) on up to 30MPH. I've been getting my best mileage yet this week, as I changed the oil to Royal Purple (yes, after years of being a nay-sayer, I bit the bullet), installed a K&N filter, added air to the tires (36PSI) and rotated them.
Averaging 22.6MPG this week, up 3MPG from all previous attempts.
Old Jul 30, 2009 | 05:44 PM
Ed Blown Vert's Avatar
I am in SD also. Is yours white??
Since changing the wheels I am getting 17-18 now. But the tires are taller so my speedometer is a bit off.
Old Jul 31, 2009 | 10:28 AM
fjungman's Avatar
Mine is black with a cargo carrier sticking off the back. Someday I'll post a pic.
If you have taller tires, the dealer should be able to recal your speedo. Since they are taller you are going farther than the truck thinks you are.
Tell me the tire size and I'll tell you your real MPG.
Old Jul 31, 2009 | 06:03 PM
I have only seen one other white one.
275/55-20 are what I am running now.
Old Aug 6, 2009 | 04:37 PM
ShakinEakin's Avatar
Hey, I'm in San Diego as well... Small world.
Mine is black, and I've only ever seen one that is white (maybe the same one Ed's seen).
C.
Old Dec 26, 2009 | 04:41 AM
sanosteam's Avatar
Hybrid in Jordan
Is it ok to switch the wheels on the hybrid. do you have any recommendation since you had yours done.
Devonaut
Aug 3, 2006 01:29 AM
mstorz
Introductions
Jun 2, 2006 08:17 PM
jahwerx
Jun 7, 2005 05:13 AM
Jason
Dec 22, 2004 12:20 PM
eak354
Feb 20, 2004 03:16 PM
