Door hinge problem
Old May 26, 2014 | 05:37 PM
jimr5454's Avatar
Default Door hinge problem
Passenger side door lower hinge is making a loud pop/creaking sou do at the fully opened position u can see the hinge plate on the door side separate slightly from the door at the time of the noise but I can't seem to tighten it and I even took the panel of just in case theres a bolt inside I was u aware of but there isn't .so if I can't tighten it what's the cause if it isn't loose ? I have pictures and video if anyone might be able to help.id weather not spend a $100 when I can fix it myself .
Old May 26, 2014 | 05:51 PM
Default Re: Door hinge problem
is it the spring? you might want to post a pic or video?
Old May 26, 2014 | 06:17 PM
jimr5454's Avatar
I'd love to post the video but please tell me how?
Old May 26, 2014 | 07:49 PM
you will need to get a youtube account and post a link.
Old May 26, 2014 | 08:12 PM
jimr5454's Avatar
I believe I linked correctly.hinge issue video you can hear the sound the inside doesn't have any visible play but the outside does .
08 yukon hinge:
a2t
25
Apr 25, 2015 08:10 AM
miketeri
Sep 9, 2010 09:24 PM
feg38
May 16, 2005 11:06 AM
Jason
Feb 27, 2004 01:39 PM
