Codes P0BBD and P0AC4
Old Apr 7, 2020 | 04:04 PM
Zroskyline's Avatar
Default Re: Codes P0BBD and P0AC4
I’m in Houston tx
will it hurt to with a bad battery pack
Old Apr 7, 2020 | 04:26 PM
Hot zone. Likely why it's failed at lower mileage.
The battery pack will deteriorate to the point of 1) poor performance/power/sluggish accel, 2) the car dies when transitioning between EV and gas, 3) the car dies randomly, 4) car won't start.
The hybrid battery is 1,000% integrated into the propulsion system, so there's no driving it without the hybrid battery. You'll likely want to stop driving it after the first couple times #2 occurs.
Old Apr 16, 2020 | 10:46 AM
Zroskyline's Avatar
dam well that’s for letting know the signs of it going out because I haven’t seen it yet but the light is on I’m thinking it sat at the dealership for awhile and I’m the lucky person to buy it
Old Apr 16, 2020 | 11:08 AM
I've updated the Silverado thread with additional data:
https://www.greenhybrid.com/forums/f...iles-p0-32286/
Tested 21 of the 40 modules - all were complete garbage. I also repeated the discharge test after replacing all 40 modules with brand new ones.
Old Apr 18, 2020 | 02:16 AM
Tahoe_08's Avatar
that is not always the issue
I had all 3 of those
Spoiler
Old Apr 18, 2020 | 06:59 AM
Spoiler
Until you have conducted testing to eliminate the battery, you can't say it's not the battery.
Old Apr 18, 2020 | 08:56 AM
Zroskyline's Avatar
I’m assuming it is the battery I called the dealership I bought it from and they had it on the floor for about month and half so I’m assuming it sat there not running I do have have a light misfire but it could be that I still have the spark plugs it first came with since the mileage is about 124k
Old Sep 17, 2020 | 09:57 AM
gchalmers's Avatar
I am having a similar issue with a 2010 GMC Yukon. Where can you purchase new cells for the battery?
Old Sep 17, 2020 | 09:58 AM
Dealership. Toyota is the only manufacturer of their product, and they only sell them in assembled batteries.
Regardless of what you may be led to believe by YouTube, all 40 modules need to be replaced.
Old Sep 17, 2020 | 10:09 AM
Zroskyline's Avatar
I went with green bean battery they came and replaced the whole modules and has a lifetime warranty if anything were to happen to it they came the next day to replace mine when I ordered it https://greenbeanbattery.com/cadilla...y-replacement/
