Code scanner that will reset HVC ID but also allows PCM modification
Old Sep 19, 2017 | 11:51 AM
Frank M. Wood's Avatar
Default Code scanner that will reset HVC ID but also allows PCM modification
My truck was in an accident and now it's disabled for the HVAC ID and probably airbag can anybody recommend a decent scanner alternative to the tech to that I reset it but also allow me to modify or calibrate speedometer and such like that and change sensor settings
Old Sep 20, 2017 | 11:52 AM
Default Re: Code scanner that will reset HVC ID but also allows PCM modification
Nobody can help me can you recommend a good scanner/tuner and general for me at least
Old Sep 21, 2017 | 11:45 AM
Hillbilly_Hybrid's Avatar
Your truck has a crash sensor for the High Voltage. Right now the most likely only to reset it is with a GM scan tool. And no tool I know of allows you to change speedometer.
Old Oct 29, 2018 | 05:40 PM
dnt1010's Avatar
So what is the recommended GM Tech 2 tool for an 09 Tahoe Hybrid. I see that they cost a few bones but owning a 9 year old hybrid with 196k miles looks like it would make having one on hand a necessity. I did a quick internet search and just became even more confused LOL
Old Oct 31, 2018 | 12:01 PM
The Tech 2 or newer MDI are the GM tools.
David Ojeda
34
Dec 18, 2020 08:22 PM
Pete4
Aug 26, 2018 12:01 PM
Mikee
Nov 13, 2014 07:33 PM
UWAdventurer
Nov 25, 2010 05:28 PM
grandpa
Nov 25, 2009 06:23 AM
