code p2729 info
Old Apr 2, 2016 | 10:25 AM
dszx13's Avatar
Default code p2729 info
anyone have part numbers? tips on removal/installation? truck has 142k on it an the trans hasn't been serviced so i'm planning on changing the filters an draining the fluid an putting in new. should it be flushed? wouldn't that cause problems being higher mileage?
Old Apr 2, 2016 | 11:02 AM
dszx13's Avatar
Default Re: code p2729 info
also curious if continuing to drive it will cause any damage to the hybrid 1 and 2 clutches
Old Apr 2, 2016 | 11:08 AM
dszx13's Avatar
pic of the truck. 09 sierra 4wd. I put a 4/7 drop on it and decladded stock gmc 20s an had them powder coated
Old Apr 5, 2016 | 05:29 AM
dszx13's Avatar
Apparently its a restricted part from gm. They want to run several tests before they can approve of it be a bad pump
Old Apr 5, 2016 | 05:46 AM
dszx13's Avatar
decided to check the codes since it was working properly. no p2797 but had a p0ac4 code.
Lone Ranger
Sep 21, 2010 05:09 AM
MMooney
Feb 28, 2006 09:05 PM
n1ywb
Jun 29, 2005 02:07 PM
Stevo12886
Off Topic
Jun 12, 2005 11:14 AM
JackC
Off Topic
Feb 19, 2004 11:43 AM
