Brakes
Old Dec 11, 2009 | 06:53 PM
T-Pole's Avatar
Default Brakes
First off, just wanted to say that this forum is very informative!
Also, this is not to restart the whole "brake failure" debate again. (that is a long thread)
I recently had the Tahoe in for the clutch plate pressure recall. When I got home, I noticed that there is a 'delay' in the brakes. I have yet to bring it back to the dealer, just wanted to see if anyone else experiences this, or might know what is happening.
At any speed, when you push the brakes, there is about a 1/4 second delay before anything grabs. At speed it's not noticeable, unless in a panic stop (that 1/4 second seems to take for ever!)
It is very noticeable when trying to inch forward in the garage. If you keep some pressure on the pedal, it is acts normal. It's when you let the pedal come all the way back and then press it again I experience the delay.
Anyone else?
Old Dec 12, 2009 | 08:51 AM
kklein's Avatar
Default Re: Brakes
Hi T-Pole,
I have not notice this.
Old Dec 12, 2009 | 08:56 AM
fjungman's Avatar
Default Re: Brakes
Sounds like they screwed up the reprogramming (just a guess). The first bit of brake pedal travel is when the regeneration should start, and that should be instant. I wonder if they didn't get one of the controllers programmed properly.
I notice no difference in the braking since getting the recall work done. Take it back ASAP.
Old Dec 12, 2009 | 09:15 AM
jet1's Avatar
FLY NAVY!
Default first post...
and its about brakes...in ONI we would consider that a suspect post...perhaps a new identity for an old poster etc etc...call me skeptical.
Old Dec 12, 2009 | 02:26 PM
T-Pole's Avatar
Default Re: first post...
Originally Posted by jet1
and its about brakes...in ONI we would consider that a suspect post...perhaps a new identity for an old poster etc etc...call me skrptical.
My problem is not a complete failure of brakes though. I'm not trying to start a big debate either! (I have no other names here)
I've owned the Tahoe for just over a year, and it's been great.
I assumed my brake problem is a programming issue, and will take it back when I have time. I just wanted to know if I was the only one experiencing this after the recall.
Old Dec 12, 2009 | 04:04 PM
jet1's Avatar
FLY NAVY!
Default its my nature
to be skeptical....I have experienced no issues except for the fact that it goes into V4 earlier than it did before the change.
Old Dec 12, 2009 | 06:10 PM
txav8r's Avatar
Default Re: Brakes
No changes in braking after the transmission reprogram on my '09 Silverado Hybrid...
Old Dec 13, 2009 | 12:53 PM
Canuck's Avatar
Default Re: Brakes
My braking is fine too.
Old Jan 7, 2010 | 06:05 PM
T-Pole's Avatar
Default Re: Brakes
Finally got a chance to bring the truck in. Service writer acted like I was nuts describing the 1/4 sec delay in the brakes, but said they'd look into it. Got a call today, they did notice it too, and fixed it. They said they had to reprogram the brake (pedal?) position sensor. Something about it was messed up from a learning process when they did the last recall.
I'll post up more if it says more on the service receipt when I get it tomorrow.
Old Jan 7, 2010 | 06:20 PM
fjungman's Avatar
Default Re: Brakes
Yes, there are very detailed instructions on this exact topic when they reprogram the vehicle. There are even warning messages in the instruction that doing this wrong will result in improper brake operation. They weren't paying attention in class. Just so everyone is aware, what dealer was this, we need to keep track of the good and not-so-good hybrid service dealers.
Thanks for following up!
