blackstone lab UOA(used oil analysis)
Old Feb 8, 2014 | 06:54 PM
GeorgiaHybrid's Avatar
Default Re: blackstone lab UOA(used oil analysis)
evois,
Do you have and use a block heater in your engine?
Old Feb 8, 2014 | 08:48 PM
Originally Posted by GeorgiaHybrid
evois,
no, I have never used a block heater at all. I use mobil 1 synthetic and watch the oil pressure of the engine and drive conservatively until it reaches operating temperature and pressure.
Old Feb 8, 2014 | 10:53 PM
With the tin and lead levels being as low as they are, the copper is not coming from the main/rod bearings. The only thing I know that could cause that level of copper would be a copper based anti-seize on an oil gallery plug or somewhere else that is in contact with the oil and leeching into it.
I doubt it's your oil as I run Mobil One in everything except my F-350 diesel ( Shell Rotella T6 for it) and have never had a problem in the 9 current family cars nor in any that preceded them including several that went over 200,000 miles and most of them went well over 150,000 miles.
Old Feb 9, 2014 | 07:36 AM
as you can see the numbers normalized(3rd=left) from the 1st(right) and 2nd(middle) samples and I did not repeat it again since it had a good TBN, etc.
Old Feb 9, 2014 | 07:55 AM
I take it you hang out over on BITOG as well?
Old Feb 9, 2014 | 09:18 AM
not really unless somebody quotes a link from bitog. the only time I looked was when I was looking for the German Castrol for my range. but it is a good source of info if you are looking for oil applications for engines. I found Mobil 1 extended performance to be as good as any full synthetic that I change the oil interval for my 200k+ miles honda pilot to every 15k miles. after several black stone samples of course.
evois
Nov 28, 2016 07:19 PM
gpsman1
May 31, 2012 07:10 AM
Orient Express
Dec 6, 2008 11:23 AM
bwilson4web
Mar 13, 2007 07:01 PM
bar10dah
Off Topic
Feb 4, 2006 03:18 PM
