Battery - Test, Recondition, Replace
My wish is to accomplish multiple items from this single post.
Background: Have a 2008 Yukon Hybrid with original 300V battery. Currently experiencing the engine revs, slipping and stalls. While the codes do not point to the main battery pack, Thanks to Dirtrunner21 we think we finally have a path forward. He was experiencing the same behavior and replacement of the 300V battery was the resolution. Here are his comments: https://www.greenhybrid.com/forums/f...09/#post260057
In addition, we've had the truck at the local dealer numerous times without any clear indication they understand the real issue. Tired of paying for minor league services and wanting to keep this truck for several more years, I have the following questions:
What is the best test for the condition of the battery? Does it have to be done at the dealer or can an independent hybrid location provide the service.
We're in the Dallas/Ft Worth Metroplex - are there any recommended shops who are the real deal when it comes to hybrids?
If it does come down to battery replacement, are the following viable (and what are the advantages/disadvantages):
Reconditioning existing battery?
Replacing with a rebuilt battery?
Replacing with a new GMC battery?
Replacing with an aftermarket battery?
If an aftermarket battery - any recommendations?
Many Thanks,
Steve
Many Thanks,
Steve
Many Thanks,
Steve
Many Thanks,
Steve
[My fealer has tolde my hybrid battery pavk is bad $3370 installed i have found used ones for ALLOT less but unsure of that route .my truck trans slipped and jerked and didnt like going from electric to engine at all then it was fine for a few days all sorts of engine codes thrown so had to take it in .gm says it is the battary pack .seems like allot of money but love the truck even almost 200,000 miles ot is a joy to drive when running correct .any ideas or comments on price dealership is charging me .. i will be giving a yes or no tommarow.truck is still frivable for sure just feeling un reliable.. jimr5454@yahoo.com
So... the jerking and stalling was getting to the point that something had to be done. GMC dealer quoted $4,600 for a new battery pack installed. I live in the DFW area and found a shop that specializes in Hybrids. They quoted $3,300 installed. We're at 165,000 miles and love the truck as well.
Glad I did it. Solved all problems. No stalls, no jerking, no slips.
The truck has been running great. Really. We're getting back to having the pure electric drive pop at every light along with extra help with acceleration.
Shop that did the work was Fifth Gear in Lewisville, TX
https://fifthgear.biz/
The warranty was for a year and I believe I'm approaching a year. Still glad I had the work done.
Every pack I build is the best I possibly can. I have built in the vicinity of 100 packs. I offer a longer warranty than anyone in my area. I have a very low warranty rate, and all my warranties are attributable to process deficiencies that have been corrected for over a year. I don't have a single warranty that hasn't already been "fixed" by correcting the cause. 40% of my warranties were voluntary replacements BEFORE the customer had an issue because I was able to determine that an issue on one would be an issue on others.
The point?
I can promise you that nothing *I* can do is worth $2900 to you. I can promise you that nothing *I* can provide gives you comparable value to a new pack at $3800. Period.
At $2,900, you should HOPE you are getting a low-mileage salvage pack that was recently pulled from a wreck and that NO ONE has ever cracked it open and screwed it up.
If your goal is long term ownership, the best VALUE is ALWAYS a new pack.
The likelihood of going 100K miles with a new battery is VERY high.
The likelihood of going 100K miles with a "reconditioned" battery is zero. You WILL have to deal with it again - likely inside of 3 years unless of course it's a low mileage (like 20K) salvage battery.
Good luck,
Steve
