another truck issue
Old Jan 24, 2018 | 10:23 AM
dszx13's Avatar
Default another truck issue
09 sierra with 173,5xx miles. ive noticed my fuel mileage has decreased lately. the other I noticed the truck wasn't going into autostop. when I pressed the accelerator pedal the engine revved up. I let off and it tried again. its been doing this for a week now. seems to be getting worse. ive scanned the entire truck several times using a tech 2 and no dtcs to be found. the truck kinda jerked when it revved. I replaced the aux trans pump a few months ago and its not the same jerk feeling ive felt with that. expecting a major component to be on its way out the door. trans or the hybrid battery. my cost on the trans is 3,156. I cant find a hybrid battery unless I get it from an aftermarket place at 3,450. any input?
Old Jan 24, 2018 | 11:13 AM
Default Re: another truck issue
I'm not familiar with the Sierra, but...
If you are using your heater/defroster more than usual, that can cause the ICE to run more. Additionally, very low temperatures can adversely impact/disable the hybrid system.
Old Jan 24, 2018 | 11:33 AM
dszx13's Avatar
not really. its been in the 30s but now in the 50-60s but I don't really use them. It gets hot in there real quick. lol. the way it acts on take off and revving up without actually moving is my concern.
Old Jan 31, 2018 | 07:50 AM
tiktok4321's Avatar
An 09 with 173,xxx miles is well within the expectation of needing a new battery.
Only if you can't get a new one from a dealer, I'd check out http://www.besthybridbatteries.com/p...hybrid-battery
Old Feb 1, 2018 | 10:48 AM
dszx13's Avatar
I removed the battery cover last week and cleaned the vent. no issues since
Old Feb 2, 2018 | 07:47 AM
tiktok4321's Avatar
That's the BEST answer!!
Old Feb 2, 2018 | 09:14 AM
Did you happen to take before and after pics? I wouldn't expect that to be a fix unless the cooling system was notably compromised.
Old Feb 2, 2018 | 10:26 AM
dszx13's Avatar
no I didn't. the screen was 3/4 covered in crap. I never removed the cover since ive had it almost 4 years. I always keep the inside clean. but so far so good
Old Feb 2, 2018 | 11:30 AM
Usually cooling system performance issues will generate a code for that coincident with any actual battery performance issues. The car knows the load, the temp and the cooling system output. When those numbers get out of sync, it throws the corresponding code.
Regardless, I hope the fix works!
Old Feb 2, 2018 | 11:40 AM
dszx13's Avatar
ive scanned it multiple times with a tech 2. no dtcs anywhere. its not as cold as it was when this was going on also. ive since got my Yukon up and running just incase it does lay down me. lol
