AIR PURIFIER - Cabin Air Filter for a Yukon
Old Nov 5, 2009 | 03:18 PM
Canuck's Avatar
Default Re: AIR PURIFIER - Cabin Air Filter for a Yukon
lol...
Old Nov 18, 2009 | 02:25 AM
sanosteam's Avatar
Hybrid in Jordan
I couldn't find any after market HEPA filter for my Yukon. Have any one tried to fabricate one. should it be placed in the outside or under the dash?
http://www.sanosteam.com
Old Nov 18, 2009 | 06:06 AM
kklein's Avatar
Cool Re: AIR PURIFIER - Cabin Air Filter for a Yukon
Well if you really want to install one on the Chev equinox it is placed on the inside above the front passengers seat in the air duct. Not sure about the air duct structure in the Tahoe hybrid, but putting it on the inside may make it easier to install and change. Maybe look at the Air Filter for the equinox and see if you can get it to fit somewhere, at least you would have the filter and bracket.
Old Dec 26, 2009 | 04:32 AM
sanosteam's Avatar
Hybrid in Jordan
I was just cleaning the carpet in the Yukon and found more smoke suds "from the road" around the battery than i did in the front. Is the hybrid battery vented to the outside?
Old Dec 26, 2009 | 07:17 AM
KC135R's Avatar
Yes the cooling fan inside the battery pack pulls inside air and vents it to the outside. If you ever pull the access panels up over the pack, you would see it on the driver side. But I wouldn't recommend doing it, because those interior trim clips are fragile and there are quite a few of them. You're almost certain to break one of them, and then you might end up with an annoying rattle.
dgyimao
Dec 31, 2009 09:38 AM
bugs
May 26, 2009 12:05 AM
Casper49
Dec 1, 2005 09:58 AM
nycspud
Nov 20, 2005 02:02 PM
cbxtc6
Dec 20, 2004 10:27 AM
