2011 Yukon Hybrid A/C went out...1 month after warranty
Old Jun 10, 2019 | 12:05 PM
SonomaGTLS6's Avatar
Default 2011 Yukon Hybrid A/C went out...1 month after warranty
I’m a DIYer and am half tempted just to buy a r-194a recharge kit with POE oil to try to recharge it. Literally my hybrid components warranty expired May 9. Also found a broken header bolt...being the AC and aluminum 6.0L are hybrid specific, has anyone had any luck getting dealer to recharge their A/C within warranty, let alone just out of it?
Old Jun 12, 2019 | 12:23 AM
dnt1010's Avatar
Default Re: 2011 Yukon Hybrid A/C went out...1 month after warranty
Are you replacing system components? Unless you have replaced a component or had a line leak that released system oil you do not need to add any refrigerant oil. The Hybrids specify a special refrigerant oil but if you just need to recharge the AC just use R-134A without any additives. Do you have a set of manifold gauges? I hate to see people go at this blind without proper equipment especially when you can buy a set so cheaply.......I love my expensive Yellow Jacket Equipment, but it is not a necessity. A cheap set less than 50 bones (tank of fuel) will work just fine for the occasional user.
Old Jun 12, 2019 | 04:33 AM
Thanks for the response. I’m not sure if the oil leaked out but will look before either taking it in or doing it myself. I may just buy a manifold set since one of my other cars AC is also getting weak...I know i’ve seen the dual gauge kits at Harbor Freight.
If I did have to add oil, do you know the procedure for that?
Old Jun 12, 2019 | 05:56 AM
Toyota recommend that you not use equipment that is exposed to non-hybrid oil, i.e., if you get a set of manifold gauges for the hybrid, only use them on hybrid-electric compressors. Honda too. I assume GM would be the same since contamination with non-hybrid oil has the same implications.
j2ram
15
Oct 4, 2018 01:19 PM
mulletman13
Jul 16, 2016 10:31 PM
Tresguey
Jun 28, 2016 04:48 PM
hmkinms
Jul 22, 2010 10:50 AM
Eskimonio
Aug 29, 2006 07:28 PM
