2009 Sierra 4x4 humming on cold start
Old Aug 26, 2012 | 08:10 PM
Hweissert's Avatar
Default 2009 Sierra 4x4 humming on cold start
Hi all,
New to the hybrid world. Just bought a used 09 Sierra 4x4 and am trying to get used to the hybrid sounds. One iv particularly noticed is on start for a few seconds, i notice a humming noise from beneath the hood. It's longer on cold starts and goes away in 10 or so seconds. Kinda sounds like a pump priming or something. Does it some on warm starts too but not as pronounced or as long. Is this normal? Or, something I need to go to the dealer for. It only has 28 k miles and bumper o bumper until march of 13.
Old Aug 27, 2012 | 06:12 PM
Hillbilly_Hybrid's Avatar
Default Re: 2009 Sierra 4x4 humming on cold start
There are a pair of coolant pumps in front of the engine and behind the radiator fans. They can be heard for several seconds after key off too. If it is them. There have been transmission oil cooler lines that touch the frame or body, they can make noises.
Engine running when heard?
Old Aug 28, 2012 | 09:50 AM
Hweissert's Avatar
Yes it is when the engine starts. I have also sort of narrowed it down to where it is louder or longer
Lasting when foot is depressing brake when the engin is started. Would that make it easier to explain?
Old Aug 28, 2012 | 10:59 AM
HyHoe's Avatar
aka soulsea
Hi H,
Usually the best way to diagnose these things is for you to take a short audio clip and post a youtube link ... that way if someone has experienced it before they can identify it.
Cheers!
Old Aug 28, 2012 | 05:50 PM
If the movement of the brake pedal makes it come on, it could be the ABS pump building pressure. The ABS pump is on the drivers side under the floor under the drivers seat.
From Auto-Stop (quiet EV) in park, pump the pedal several times. You will hear and possibly feel the ABS pressure pump. If that is not the noise, HyHoe's advice is still best here.
treefarmer
General Motors Corporation
12
Sep 23, 2019 11:15 AM
danieloneil01
15
Nov 18, 2018 03:16 PM
medicstl
Nov 19, 2014 07:31 PM
dcw888
Feb 27, 2012 10:23 PM
krousdb
Oct 22, 2005 11:49 AM
